Old 04-03-2007, 03:46 PM   #1
mzbmw325i
mzbmw325i's Avatar
auto tranny fluid/mounts
ok, here are my questions
according to the realOEM site, my tranny is a 4HP22-GA, automatic, yes i know auto sux but that is along story, still like my bmw though and i want to flush the tranny fluid.
what is the recommended ATF fluid or what r most of u guys using if u have auto tranny, on the car manual says anything that is Dexron Mercon 2, i also read the redline fluid is pretty good but pricey.
tranny mounts,
i came across somewhere on the net that the oem tranny mounts are weak and some1 suggested using the mounts for a E21 or something, should i stick with the oem mounts or get better strength, aftermarket kind.
Old 04-03-2007, 06:25 PM   #2
Rate My Car: 106 / 337
Red Line is a little more money, but well worth it. You'll feel the difference. And try to get aftermarket mounts, since you're planning to replace them anyway- much more solid performance and shifting.
Old 04-03-2007, 07:56 PM   #3
mzbmw325i
mzbmw325i's Avatar
Is the Castrol Dexron Mercon synthetic as the redline auto tranny fluid, i checked the local store that has some redline fluids and it's 10$ per quart. the Castrol Dexron Mercon is like $4 a quart.
what after market mounts are recommended?
e36 auto tranny? Mercenary(FH) E36 12 12-27-2006 11:00 AM
Tranny Trouble clarkstreet 7 Series (E23, E32, E38, E65, E66) 1 10-04-2006 08:23 PM
Found a used Tranny (long post) dinan540 E12, E28, E34, E39, E60 35 03-21-2006 03:28 PM
Need Auto Tranny Recommendations 1fast325i E36 5 03-09-2006 12:40 AM
Something New At Premium Auto Care Dwayne@PremiumAutoCare Detailing and Cleaning 1 09-19-2005 11:55 AM
