Old 03-29-2007, 08:26 AM   #1
moetinger
Your Ride: 1990
Door locks stopped working
Left my car parked for a while and the door locks do not work. The battery died and I had to jump it. Did that blow a fuse? Cannot find one anywhere.
It's a 1990 325 convertible.
Thanks for the input.
Mark
Old 03-29-2007, 10:21 AM   #2
mullethunter3
mullethunter3's Avatar
Rate My Car: 163 / 337
I'm assuming that your doors are electrically locked and not manual?
Anyway, here's a diagram of all the fuses in your car:
I got it from here:
E30 Performance
Looks to be that locking is under fuse #27, it's a 30 amp.
Oh, and the fuse box is driver's side, near the firewall, in case that's what you meant when you couldn't find it.
Old 03-29-2007, 10:29 AM   #3
moetinger
Your Ride: 1990
Thanks for the diagram. I will check the fuse first. I was told a while back there is a wire above the passenger side speaker in the kick panel that gets tripped when you jump the car?? This will cause the locking actuator not to work. Any truth to that?
Old 03-29-2007, 12:07 PM   #4
Dr1ve4fun
Rate My Car: 235 / 337
Your Ride: 1985 325e
^^That at least wasn't true for me...since the first day I got mine we had to jumpstart becase it had been sitting for a few weeks..but I have an 85 e so..I guess it could be different.
Old 03-29-2007, 01:00 PM   #5
moetinger
Your Ride: 1990
Well, the fuse is fine. If anyone has other suggestions, let me know.
Thanks!
Old 03-29-2007, 07:00 PM   #6
theSMELSINATOR
theSMELSINATOR's Avatar
Your Ride: 1990 325iX
mine don't work like they should, but you can lock/unlock them from the trunk.
Old 03-30-2007, 01:03 PM   #7
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
None of mine work right now at least the power function. There are a couple places to look. You can check the unit in the trunk, there is also a small box under the drivers side front speaker, remove it and there are reports that a connection breaks and you can solder it back together and your back in business. I still have not had a chance to try it though.
Old 04-04-2007, 07:38 AM   #8
Bubba
Door Locks
Go here: http://www.bimmerdiy.com/e30
I had issues with a 1990 325ic and ended up replacing (from salvage) the central lock controller and driver door lock solenoid ) about $100 total, and all is now well.
Old 04-05-2007, 04:42 PM   #9
theSMELSINATOR
that diagram is for an m3. is there any difference?
blinkfile thumbnails not working? craig United Off Topic  **FOR MEMBERS ONLY** 3 12-06-2006 09:27 PM
Hood Dampers not working billycuth E36 18 12-04-2006 08:35 AM
OBC quit working Dr1ve4fun E21, E30 22 09-17-2006 02:00 AM
started working on the e30 e30boarder E21, E30 30 02-02-2006 09:20 PM
Working at the Coolest Place (pics) BimmerKris United Off Topic  **FOR MEMBERS ONLY** 27 05-14-2005 12:54 AM
