Old 03-07-2007, 03:43 PM   #1
roage
Your Ride: 1985 325e
engine knock knock kcocking.
new to this forum so be gentle!
i recently purchased an 85' 325e and have a question/concern regarding engine knock. the car seems to have a diesel sounding knock at idle to 2000rpm...(not sounding likea lifter tap, but a knock)
it also idles irraticaly from time to time (vaccum leak?)
needless to say she's running a little rough.
the cap, rotor, plugs, oil, oil filter and fuel pump are all fresh. (i have a fuel filter which i will install soon.)
point me in the right direction please!?
Old 03-07-2007, 04:08 PM   #2
Rate My Car: 84 / 337
Has the ignition timing been checked?
Old 03-07-2007, 04:18 PM   #3
roage
i suppose that would be a good starting point.
i'll check that out...
Old 03-07-2007, 06:05 PM   #4
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 119 / 337
Your Ride: ^^
no knock sensors on M20? if so then check that?
also im sure the vacuum hoses are all worn out. Go to realoem.com and check all the vacuum lines you may need. I changed mine out and the car idled better and seemed to have better performance.
Old 03-07-2007, 08:27 PM   #5
roage
thanks, i'll look into that too.
Old 03-20-2007, 09:54 AM   #6
roage
got it checked out...looks like the rod bearings are worn and quite possibly the main bearings....time for an inframe bottom end rebuild. or is it even worth it?...find a rebuilt motor?...drive her til she drops?...The erratic idle was related to intake gaskets being blown. She runs good now, except for the knocking.
Old 03-21-2007, 05:52 PM   #7
Littlebimmer
Littlebimmer's Avatar
Your Ride: 1989 325i
its still running man, means its rebuildable so yes, its worth it enless you can find a running engine for really cheap like under 500 bucks
Old 03-21-2007, 07:24 PM   #8
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
Yeah a cheap motor or swap to something else or rebuild it.
325is Turbo Project, Engine upgrades? BmwCrazy325 E36 9 06-15-2011 01:15 PM
Dressing My Engine GreenTourer Detailing and Cleaning 11 10-01-2007 10:28 PM
Engine Differences htp.bmw E21, E30 4 09-19-2007 10:34 AM
Car stalled and now engine won't turn over... looking for any ideas/help komodo M3 21 05-22-2006 11:15 PM
Search Engine Optimization and Tweaking komodo United Off Topic  **FOR MEMBERS ONLY** 23 04-07-2006 11:12 AM
