Old 03-07-2007, 02:43 PM   #1
mzbmw325i
mzbmw325i's Avatar
E30 transmission fluid change and gasket change
has any1 done a fluid change on a E30 and also cleaned the pan, replaced o-ring and gasket?
i managed to find some DIY's on other bmw models but those were newer trannys and it looks like the E30 is easier to do.
what is the preferred choice of tranny fluid besides that expensive dealer crap.
i am planning to change the front rotors/pads and also do the tranny, my dad is going to help since he knows about rotors/pads, but i wanted to touch basis on the tranny fluid change if any had pointers here. Thanks in advance
P.S. if any1 has a DYI link is greatly appreciated.
Old 03-07-2007, 03:15 PM   #2
celsdogg
celsdogg's Avatar
Title: never gonna happen
Rate My Car: 128 / 337
havent done it, but here are some resources where you may be able to find something:
http://bimmerportal.com/diy/e30.html
http://www.unofficialbmw.com/e30/index.html
http://www.bimmerdiy.com/e30/trans
Old 03-07-2007, 04:18 PM   #3
mzbmw325i
mzbmw325i's Avatar
celsdogg
thanks for the links, btw the links u listed i have those, the funny/sad part is the exact DYI on auto tranny fluid change does not work on any of the sites, if any1 has that DYI saved can you provide it.
thanks
btw it is an automatic transmission in my E30.
Old 08-03-2007, 01:30 PM   #4
mzbmw325i
mzbmw325i's Avatar
yesterday in the mail i ran into a coupon for a tranny fluid service for 90$,includes gasket and filter. it's one of the local shops "good year" i think is called, i don't know if they are a nationwide chain.
is it safe to take it for tranny change to one of these mostly "domestic" oriented vehicles shops" or always to a certified BMW shop. what is your thought?
can they really screw it up
Old 08-03-2007, 04:03 PM   #5
Maritime Bimmer
Your Ride: 1995 325IS, 1986 325E
I just used A Dexron III ATF when i swapped the tranny out of my 325e, It was over a year ago, but i remember the pan being a pain to get back on with the gasket, and making sure the fluid level was perfect took a little bit of time,
Time to change the head gasket or..? mr-bear E36 7 01-09-2007 02:35 AM
