Old 03-02-2007, 03:10 PM   #1
chocoisa
Your Ride: 325i 1989
Presenting myself and seeking advise
First of all, I want to introduce myself, I am from Guatemala Central america and I hope I can find here answers to my questions and help if I can.
Then I want to ask for advise on how bad you guys think my problem is. Well I have always wanted to have a BMW and finally yesterday I bought one in Copart, it had a rear crash, meaning it doesnt have a trunk jejejejejeje. Well I bought it for $225.00 and will be brought to Guatemala to be repaired. Labor is cheap here and I just need to find parts to fix it.
I will post some pics so you can comment on the damage.
Suggestions are welcome, for example if you think the rear axle was damage, or the gas tank, etc etc, and also how hard can I find parts.
It is a E30 325i 1989 automatic.
Also can someone tell where to run my VIN so I can find what package my car had?
Old 03-02-2007, 03:22 PM   #2
RSF5
RSF5's Avatar
Rate My Car: 277 / 337
Your Ride: NOOTHHHIIIINNG
Lets see... everything from the rearseats back needs to be replaced. I believe that is what is called "totaled". The rear axle doesn't look too bad but you can't really see from the pictures. Oh and you probably need a new frame.
Old 03-02-2007, 03:35 PM   #3
elsabor67
elsabor67's Avatar
Rate My Car: 33 / 337
OWWW!!!!! I sure hate it for the person that was in the car when it happened . I would really recommend you to take a REALLY GOOD LOOK at the frame when you get it. That does look really bad, but who knows. To run your VIN, go to www.realoem.com (thanks C1) and once you put your vin you should get the info you need. Good luck.
How do I spell relief??
AUTOBAHNNNNNNNNN
"GO FASTER !!"
Old 03-02-2007, 03:40 PM   #4
mullethunter3
mullethunter3's Avatar
Rate My Car: 163 / 337
Pelican Parts
That website is where I get all my parts. They are very good at shipment times and are also very friendly.
Old 03-02-2007, 04:39 PM   #5
chocoisa
Thanks guys, but please explain what do you mean by the frame?
Sorry I am dumb on this
Old 03-02-2007, 04:52 PM   #6
Rate My Car: 84 / 337
There is no frame, the car is a unit type. But the fold in the back of the roof means there is structural damage and the car will need to be straightened before a replacement rear section can be welded on
Old 03-02-2007, 05:23 PM   #7
chocoisa
That means I am really screwed???
Old 03-02-2007, 05:25 PM   #8
chocoisa
any comments on the motor bay and interior?
Old 03-02-2007, 05:34 PM   #9
From what I see the interior and the front are in good shape. The work to straighten the car might not be too bad, but I don't know
Old 03-02-2007, 07:19 PM   #10
RSF5
RSF5's Avatar
I didn't know those didn't have frames. Still frame or no, that is massive damage.
Old 03-02-2007, 08:01 PM   #11
Rate My Car: 106 / 337
Witey is correct, neither the E30 nor the E36 have frames, they're unibody construction. I think the E46 is the same as well. That definitely would be considered totalled, as celsdogg can tell you. His rear wasn't anything close to that when it was hit, and it was written off. Labor may be cheap there, but you'll need to make sure they do the job right.
Old 03-03-2007, 11:00 AM   #12
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
Looks like an exspensive proposition to make that e30 right again.
Old 03-03-2007, 12:20 PM   #13
Monark
Your Ride: 87 325
Just because its totaled here doesn't mean he won't be able to legally use it in guatemala. I can take a car from the US to Spain and be able to use it as long I get some insurance over there. It doesn't have to pass inspection or get registered there either.
Old 03-03-2007, 01:17 PM   #14
Rate My Car: 137 / 337
Agreed, but look at the damage vs parts cost. He's got a pretty expensive project in front of him regardless of how cheap labor is. BMW parts anywhere are a premium. And given the fundamentals of any "uni-body" BMW that one is going to have damage all the way to the engine compartment. (Electrical, fuel lines, brakes, drive line)
Old 03-05-2007, 09:14 AM   #15
chocoisa
just for your information the car has engine start, so hopefully it will be just a matter of fixing the trunk.
