Old 02-06-2007, 01:33 PM   #1
1985 325E
1985 325E's Avatar
Your Ride: 1985 325 E
Heater Fan Replacement
So here it is, 0 to -3 degree's in the Chicago land area, and my 1985 325E decides for the heater/ AC fan to sieze up. The question I am needing to get answered, is where is this located and how can I get it removed to replace the thing? I thought I could get at it through the dash, but I am not finding it. ANY information would be appreciated.
Thanks!!
Old 02-06-2007, 02:54 PM   #2
Rate My Car: 134 / 340
GO TO www.realoem.com - enter your info and check out the schematics there. They have great "exploded views"
Old 02-06-2007, 03:39 PM   #3
QcMarque
QcMarque's Avatar
Your Ride: 1994 740i
Chances are the blower motor is dead center of the car, right under the dash, on the outside of the firewall. you've probably got a removable cover under your wipers... pull that and you should see the blower motor cover. My local dealership told me I had to pull the dash and the entire heater core assembly to get the blower motor out, but I found with a little coersion and effort (not to mention patience) I got it out through the front instead of pulling everything apart. I'm sure you can do the same if yours is setup like that.
Old 02-09-2007, 10:00 AM   #4
1985 325E
1985 325E's Avatar
Thank you VERY much. It has warmed up tp about three degree's so I may need to use the engine warmth to warm my hands!! Again, thanks!!
Heater Fan Runs on/off all night! - 2001 540i Herr Koobel E12, E28, E34, E39, E60 5 10-18-2011 05:13 AM
electric fan won't stop! dead batterys suck! bmw_passion E36 6 01-05-2007 04:10 AM
Heater Fan Switch Not Working? c1apton BMW General Discussion 4 12-14-2005 01:49 PM
89 535i heater fan jybute E12, E28, E34, E39, E60 1 10-03-2005 08:54 PM
fan whine Spieluhr E36 5 05-17-2005 09:30 PM
