Old 01-26-2007, 10:06 PM   #1
mzbmw325i
mzbmw325i's Avatar
Watch, listen, suggestions
my E30 325i '91 engine is making strange sounds, please have a look at the clip and hear the sounds the engine is making running and i await your feedback
especially the clicking sound as i do a close up, is the engine nearing the end....it is shy of 400 miles to hit 200k
http://s179.photobucket.com/albums/w...v?t=1169870613
Old 01-26-2007, 10:12 PM   #2
Rate My Car: 84 / 340
Sounds a lot like my car! I think it may need a valve adjustment
Old 01-26-2007, 10:25 PM   #3
Rate My Car: 184 / 340
lol sounds like a diesel almost, yes something with valves, does the clicking sound get faster when you rev it up?
Old 01-26-2007, 11:23 PM   #4
mzbmw325i
mzbmw325i's Avatar
to tell u i never listened to the ticking as i step on the gas pedal, i think its the same throughout. but this ticking has been on for a while and i have been driving it like that as far as i remember.
would adjusting the valve make it sound more "normal" or it wouldn't bother it much
i noticed gas consumption is up a bit, any ideas on that?
thanks
Old 01-26-2007, 11:51 PM   #5
thanks
Usually all the valve tappets need adjusting (12)
Old 01-28-2007, 01:51 PM   #6
celsdogg
celsdogg's Avatar
Title: never gonna happen
Rate My Car: 130 / 340
you can adjust the valves it it may minimize it, but the M20 does not have quiet valve operations. they are kinda supposed to sound like a typewriter.
it sounded fine to me, and i have had two M20's. if you can, try taking an audio only clip with a higher bit rate, and while your under the hood listening, open the throttle a little bit, just pull it open with your hand. not too much now. . .
Old 01-28-2007, 05:21 PM   #7
yea u can pull the throttle open w/the cable under the hood, oh and whens the last oil change uve had? maybe if the oil is getting old(really old) the valves will be noisy, maybe you need a different viscosity
Old 01-29-2007, 11:34 AM   #8
mzbmw325i
mzbmw325i's Avatar
i changed the oil 2 1/2 months ago, i plan to change it this weekend. i use 5-30 castrol regular oil, not the synthetic one, would it make a difference if i add synthetic oil, that stuff is pretty expensive and i read somewhere that if it has not been used in a long time it i snot recommended, due to its thinness and might leak more from the gaskets on the engine. Especially my engine is almost 200k.
Change the viscosity? You mean the type of grade oil I put in or...
I live in Arizona and in the summer time I use the 20-50.
Changing the type of oil grade like that does it harm the engine?
Old 01-29-2007, 11:42 AM   #9
mzbmw325i
mzbmw325i's Avatar
celsdogg
how do i a take audio only, i used my digital cam to make the video, u mean extract the audio from the clip. after reading your replies, it seem that this is a common sound for the M20.
i may do the valve adjusting, but i am not too leaning towards it right now, would adjusting the valves also affect fuel consumption?
thanks for the input guys.
Old 01-29-2007, 12:39 PM   #10
celsdogg
celsdogg's Avatar
honestly bro, it sounds fine. but your concern reminds me of myself.
Old 02-09-2007, 09:00 AM   #11
Akuma
Rate My Car: 6 / 340
sounds like a usual M20 engine. The tappets are never quite quiet on them.
1989 BMW E30 325i Cabriolet.
Old 02-09-2007, 02:46 PM   #12
celsdogg
celsdogg's Avatar
^^^ yup. thanks for the backup
Old 03-04-2007, 05:37 PM   #13
Exilion
Exilion's Avatar
I had the same sound and I did a valve adjustment this past weekend just because it was past time to do it. It ended up making my engine twice as loud. I had a mechanical buddy check it and he said the valves were adjusted properly just that in general as cam shafts wear down their operation gets louder.
So now I'm deciding on whether or not to replace the whole assembly. Right now it's running alot better... just my little bimmer sounds like a F350 truck.
Old 03-04-2007, 05:56 PM   #14
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 125 / 340
Your Ride: ^^
I have an M42..its not taht loud. but everytime i hear an M20 it sounds like valves. I think its just the fact that its 15+ years old.
Old 03-04-2007, 06:06 PM   #15
Rate My Car: 134 / 340
I'd do the oil change to 20w-50 (since you live in Arizona) THEN do/ have someone do the valve adjustment. Tappet/lifter noise is common on those but yours is slightly louder than normal. Not a major problem but it's a maintenance item that should be done every 30k or so. Your mileage will also benefit from keeping valves adjusted.
I'm leaking oil, any suggestions nick_318is E21, E30 27 03-03-2012 03:15 PM
suggestions...engine software barney E46 8 05-20-2010 09:30 AM
Sponsor Suggestions nick_318is Site Feedback 3 11-21-2005 09:40 AM
United Subaru Suggestions Chris Site Feedback 14 10-06-2005 08:58 PM
Anyone Watch The Game Last Night? komodo United Off Topic  **FOR MEMBERS ONLY** 2 07-19-2005 11:09 PM
