Old 01-17-2007, 04:03 PM   #1
briansbimmers
Your Ride: 1984
1984 325e!!! fuel pump problems
i got a 1984 325e a few days ago and it doesnt want to start. and the guy who owned it said that if u spray staring fluid in it just as long as u keep spraying it will run.it will hit once and then die. the guy who owned it before me said that he thought it was the fuel pump in the tank but i pulled it out and everything seemed fine to me. but when i connect the battery i can hear the pump that is outside of the tank running without the igniton on is this normal? it is currnetly getting 28 ft lbs of pressure and it needs to be getting 32. i changed the fuel filter thinking that it might be clogged, since i replaced that it wants to turn over alittle better. if anyone has any ideas on what the problem might be it would be greatly appreciated
Old 01-17-2007, 06:57 PM   #2
Rate My Car: 137 / 337
Some of those early 3s have two fuel pumps, 1in and 1outside of tank - if the intank one is bad - you'll get the situation you're describing
Old 01-17-2007, 09:04 PM   #3
briansbimmers
Your Ride: 1984
well i looked at the fuel pressure regulator and i heard a hissing noise when i connect thwe battery so i am thinkin that that might have something to do with it ..a nd that s alot cheaper and easier than replacing the fuel pump
325e to i project... SMS19 E21, E30 0 12-25-2006 07:29 PM
325e mystery grandmaster B E21, E30 3 08-17-2006 11:28 PM
325e engine swap (325i) Processes PhotoGuy30523 E21, E30 3 08-15-2006 04:17 PM
1985 325E fuel pump 1042 E21, E30 6 07-06-2006 10:25 PM
FS: 1984 Hennarot 325e MrHennarot325 Bmw Cars For Sale/Wanted 1 06-24-2006 04:37 AM
