-   E12, E28, E34, E39, E60 (http://www.unitedbimmer.com/forums/e12-e28-e34-e39-e60/)
-   -   battery problem (http://www.unitedbimmer.com/forums/e12-e28-e34-e39-e60/9997-battery-problem.html)
V-tecKILLAH 01-12-2007 01:16 PM
battery problem
Heres the deal my battery needed replacing so I went to autozone and purchased a brand new battery. Now after a week of runnung the car the new battery is dead again. I do not think my alternator is bad because with the other battery being dead I drove to autozone on my alternator. I'm thinking something could be grounding out, don't really know... Any help would be greatly appreciated.
c1apton 01-12-2007 04:03 PM
take car to Autozone & have them do the free test at curbside. They can check the alts output - if battery & alt test good THEN you have a short somewhere.
V-tecKILLAH 01-13-2007 12:06 PM
i'll try that thanks
bradhouser 03-07-2007 04:07 PM
You could have a weak alternator that is putting out enough to run the motor, but not enough to charge the battery. You could also hookup an ammeter in series with the battery, with nothing running to see if you have any current flow when you shouldn't. Anything over a few mA should be looked at (clocks and radio memory need some juice.)
