Old 12-31-2006, 11:17 PM   #1
e39 bimmer
e39 bimmer's Avatar
Your Ride: 1998/540i Sport 6 Speed
E34 Service Indicator Light Reset
1. Ignition off.
2. Short pins 7 + 19 with wire (remember to put a fuse on this wire).
3. Turn ignition on and wait for about 4 seconds for an Oil Service reset, 10 seconds for an Inspection reset, then
4. Remove the wire.
5. Replace the cap on the diagnostic socket.
6. Turn ignition off again.
You must do it exactly the way described above. Otherwise it won't work.
NOTE: These steps/instructions are what worked for ME. I do not promote them as something that's recommended to do. If you do try this you are doing so at your own risk. I'm in NO WAY responsible for damages cause in connections with these steps. They worked for me on my e34 many times!
Remove the cap from the diagnostic socket (right side of the engine bay on my LHD) and this is what you will find - well, my drawing of it anyway. The pins marked with red are the ones you are looking for. Use the cut in the center Mr. Pacman for pin identification.
VROOOOM!
e39bimmer
www.uniquecustoms.org
Service Engine Soon light reset luispest 7 Series (E23, E32, E38, E65, E66) 4 06-28-2006 09:05 AM
Great Place, Great Service devinwwu Northwest Region 11 12-21-2005 12:05 AM
resetting inspection bars jybute E12, E28, E34, E39, E60 7 10-15-2005 09:37 AM
Ferrets Are Service Animals Too komodo United Off Topic  **FOR MEMBERS ONLY** 2 10-04-2005 11:12 AM
