-   E12, E28, E34, E39, E60 (http://www.unitedbimmer.com/forums/e12-e28-e34-e39-e60/)
-   -   e28 Clutch gone (http://www.unitedbimmer.com/forums/e12-e28-e34-e39-e60/9719-e28-clutch-gone.html)
Hoppy 12-12-2006 12:01 AM
e28 Clutch gone
hey guys, my clutch went over the weekend. something with the master cyclnder. the clutch pedal goes down, with no resistance and no effect and pops back up. the spring is still intact and connected. it appears to still have fluid. i can only imagine i have a leak some where. any ideas
Dudesky 12-12-2006 04:11 PM
You might just have air in there? Try bleeding the system. I know that on E36's, those symptoms are usually just air in the lines, or improper bleeding. Or you might have a damaged/torn clutch fluid hose?
Hoppy 12-12-2006 06:23 PM
i dony imagine i damaged the system, as it workd a week ago when i parked. and now it doesnt. i dont knowhow air woulda got in the system.
c1apton 12-12-2006 07:48 PM
Age & big temp changes can swell & crack the seals which causes leaks and/or air intrusion. I'd guess hose first then maybe clutch slave cylinder.
xsperf 12-12-2006 09:51 PM
you said it has fluid in there? how are your brakes do they work well? try pumping the clutch and see if it builds up pressure
Hoppy 12-12-2006 10:03 PM
hmmm it did stop working the day after a huge cold front
the bakes work ( they hold the car), iv pumped the clutch, nothing.
