Old 11-13-2006, 10:27 PM   #1
dinan540
dinan540's Avatar
Emergency Brake Failure
My e brake doesn't work on my 2001 540i. When I pull up on it, it doesn't make that familiar click. What could it be? Is it an easy fix? My car is a manual.
Thanks
540i with some mods
Old 11-13-2006, 10:37 PM   #2
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 119 / 337
Your Ride: ^^
Thanks
take off the boot that is covering it. See if anything looks amess.
Old 11-13-2006, 10:38 PM   #3
Rate My Car: 84 / 337
My first guess is the spring that holds the part that clicks is stuck
Old 11-13-2006, 10:43 PM   #4
celsdogg
celsdogg's Avatar
Title: never gonna happen
Rate My Car: 128 / 337
does it hold the car in place? or does the handle just not stay up?
Old 11-13-2006, 11:28 PM   #5
dinan540
dinan540's Avatar
Handle does not stay up and it doesn't ratchet.
540i with some mods
Old 11-13-2006, 11:36 PM   #6
I think that makes it closer to my first guess
Old 11-13-2006, 11:42 PM   #7
dinan540
dinan540's Avatar
whiteshark, should I remove the ebrake boot?
540i with some mods
Old 11-13-2006, 11:49 PM   #8
Yeah, if you know what to look for based on Numark318i's post
Old 11-14-2006, 01:05 AM   #9
drz
Title: local dumbass
Rate My Car: 32 / 337
Your Ride: E36 2.8i
Yourr cable may have come undone. Remove the boot to check.
Old 11-14-2006, 06:32 AM   #10
celsdogg
celsdogg's Avatar
if the cable came undone, then it wouldnt hold the car in place, even when you hold it up yourself.
if the handle wont stay up, that is the "ratcheting" area
Old 11-14-2006, 10:45 AM   #11
drz
Your Ride: E36 2.8i
I didn't know it was holding the car in place. He never explained that. My bad. Yeah, check the "ratcheter."
Old 11-14-2006, 11:53 AM   #12
celsdogg
celsdogg's Avatar
^^^ im not sure either way. it just sounds like that is the problem because he said it doesnt make the click, and the handle wont stay locked. id stop on a slight incline, leave it in neutral, and see if it rolls with you holding the handle up. then let it go. if it holds, the cable is fine.
i looked on realoem, looks like that if the handle is the problem, you have to replace the whole thing. if its broken that is.
Old 11-14-2006, 05:07 PM   #13
dinan540
dinan540's Avatar
Thanks for the input. I will try the stopping on the hill deal.
540i with some mods
Old 11-15-2006, 02:10 AM   #14
dinan540
dinan540's Avatar
Works on a hill if I hold it, so the cable is intact. The spring popped out, so I popped it back in and now it works.
540i with some mods
Old 11-15-2006, 08:00 AM   #15
94bmw325i
94bmw325i's Avatar
Title: Hellrot325
thats good to hear! On my friends car his handbrake recently messed up also. He doesn't have a BMW, but sometime soon we need to adjust it.
DIY Brake Pad Change nick_318is BMW OEM Parts Department DIY's & FAQ's 6 08-25-2011 09:23 PM
RSM failure and Subframe failure 94bmw325i E36 22 10-25-2006 10:28 AM
E30 Brake Pad Changing Procedure nick_318is BMW OEM Parts Department DIY's & FAQ's 6 10-14-2005 05:36 PM
Quality Brake Package (rotors, pads, lines) Spieluhr Vendor/Dealer Comments & Supporting Vendor Announcements 2 08-28-2005 02:05 PM
