Old 05-04-2006, 07:31 PM   #1
Baldingo540
Rate My Car: 42 / 337
Your Ride: 95 540i
So i may have blown my rear-end......UPDATE!
Ok, so my 95 540i (manual) had a very clear **clunking** sound/feel coming from the rear area of the car (it feels like) Its at between 4k-4500 rpm in first, and 2k-2500 rpm in second, THATS IT! no problems in any other gears. These rpm changes translate to about the same speed, just in different gears. It doesnt feel like its getting worse, and it doesnt matter how hard im hittin the throttle. One of my instructors said it sounded to him like itsot like in the rear-end. Anyone have any ideas? Its deff. a driveline issue, im gonna say with about 90% certainty that its not the tranny, but ive been wrong before, anyone ever have an issue like this?
95 540i 6-Speed
Old 05-04-2006, 10:08 PM   #2
Rate My Car: 137 / 337
Check the "guibo" joint & u-joints for starters. Other possibilities are drve axles and/or CV joints... hard to diagnose without seeing & hearing it.
Old 05-04-2006, 10:30 PM   #3
Rate My Car: 183 / 337
yea MOST likely a guibo/flex disc coupler, if you keep driving it for another month, and it gets worse, then its def. ur guibo
Old 05-06-2006, 11:58 AM   #4
Baldingo540
Your Ride: 95 540i
i just managed to get myself under the car (not an easy task) and took a look around, the guibo looks fine, i felt around on it and didnt see any major stress cracks or wear on it, also the axles are tight with no play in them, i can rotate the driveshaft a slight amount, but just enough to compensate for the backlash in the rear-end. Any other ideas?
95 540i 6-Speed
Old 05-06-2006, 11:59 AM   #5
Baldingo540
Your Ride: 95 540i
oh i forgot to add, is first gear, if im really gettin on it, the e-brake handle will actually flap up and down a little bit, just enough to make a slapping sound
95 540i 6-Speed
Old 05-06-2006, 12:23 PM   #6
Check motor & trans mounts. For cracks, tears - from your description on "E Brake" shudder that could be a mount issue.
Old 05-23-2006, 02:38 PM   #7
V-tecKILLAH
V-tecKILLAH's Avatar
While under there check the center line bearing.....had the same problem but it was my flex disc..However BMW told me that the center line bearing being worn will cause the same noise.Doubt its the tranny!!
Old 05-23-2006, 06:55 PM   #8
Baldingo540
Your Ride: 95 540i
sorry, i should have updated this, if you see my other thread in here IT IS THE TRANNY!!! GRRRRR, it still runs though, it just clunks, ill get around to rebuilding the tranny or putting in a new one eventually
95 540i 6-Speed
Old 10-15-2006, 12:33 PM   #9
subkiller
Your Ride: 1994 540iA
for me, identical symptoms.
two local shops diagnosed center drive shaft mount ( the bearing and rubber bushing were trashed; replaced and went thru another center mount in 1000 miles with same symptoms.
Turned out to me a frozen rear u joint which BMW does not sell separately from the drive shaft assbly! At least that's what BMW told me and could not find used. Spent $1000 and lost a week tied up at a BMW dealer. but the problem is gone. not the hole in my wallet. nor the feeling that BMW's FRU strategy for repairs makes them a whole lot of extra money..
Old 10-15-2006, 05:12 PM   #10
Although this is an old thread, just a heads up to all - just because BMW says it's not available without the driveshaft (re: u-joints) Clutch & U-Joint shops Do sell the u-joints and misc parts + do the installations {You bring in the shaft & they'll press them in & out for you for a fraction of the co$t of a driveshaft} They also offer other services like driveshaft balancing, CV joint & boot work & straightening of axle shafts.
Old 11-05-2006, 04:24 PM   #11
Baldingo540
Your Ride: 95 540i
just to let everyone know
i had to replace the tranny, driveshaft, and wheel bearings, yippie
at least the problem is gone now
95 540i 6-Speed
Old 11-05-2006, 04:58 PM   #12
defkon99
defkon99's Avatar
Rate My Car: 50 / 337
Your Ride: 1993 E36
dang! what a mission!
E36 Rear trailing arm bushing replacement Dudesky BMW OEM Parts Department DIY's & FAQ's 19 06-01-2011 11:02 AM
DIY: Install Rear Shades on your E36/E46/E34 BMW! delmarco BMW OEM Parts Department DIY's & FAQ's 2 11-26-2007 10:41 AM
CLICKING SOUND fROM rear end ? WTF? defkon99 E36 34 10-18-2006 01:00 PM
DIY (please sticky):Blown Rear Shock Mounts!? E36 Tower Complete Replacment! delmarco BMW OEM Parts Department DIY's & FAQ's 9 08-27-2005 02:16 PM
E46 Audio Information - This is a god-send. EcianIce Car Audio and Electronics 4 04-21-2005 02:22 PM
