Old 04-15-2006, 05:39 PM   #1
huttey
Your Ride: 1999 540i
Smile Seat Belt Adjustment
I have just purchased a 1999 540 and I can't figure out how you adjust the seat belt height on the pillar, can anyone help
Old 04-15-2006, 05:54 PM   #2
Rate My Car: 84 / 337
On a friend's car there is a push knob that releases the belt slider. Hope that helps
Old 04-15-2006, 08:53 PM   #3
huttey
No button unfortunately
Old 04-15-2006, 08:59 PM   #4
Well they are adjustable: http://www.autobuyguide.com/1999/12-...ons/index.html Any sign of the car's owner manual?
Old 04-15-2006, 09:05 PM   #5
huttey
Nothing in the manual about HOW you adjust the height
Old 04-15-2006, 09:14 PM   #6
Wow how strange. Can't find much on the net either. Maybe a call to a local dealer.
Old 04-15-2006, 09:16 PM   #7
Rate My Car: 137 / 337
Most of them automatically adjust when you move the seat(s)
Old 04-15-2006, 09:30 PM   #8
huttey
Thanks. If it is automatic, then it is broken, I will see the dealer
Old 04-15-2006, 10:40 PM   #9
BMWLotAttendant
Title: I Drive EVERYTHING
Your Ride: 1997 Camry CE
You just have to giggle it a little bit. It's all in the wrists.
Nah, it probably needs something replaced. Not too bad.
Yeah, the dealer can fix it. We can fix ANYTHING.
Old 04-16-2006, 01:41 PM   #10
DEATH2000
DEATH2000's Avatar
Rate My Car: 116 / 337
For basiclly more money than anyone has.
Old 04-16-2006, 01:47 PM   #11
Antiburn
Antiburn's Avatar
Rate My Car: 191 / 337
If you move your seat foward and watch where the seat belt comes out it should go down. If you move it back it should go up. If its broken expect about no more the 100$ for the part and maybe an hour or 2 depending on your skills.
If your cable snapped which moves the seat belt then the front seat, which ever one it is has to come out and the upper and lower pieces of the B billar have to some out. I believe E39's have T40 torx holding the seat down and the retractor under the carpet clicks in.
Once the seat is out you pull the carpet back, it should be in the lower left corner before the cross member of the vehicle. Once you have the B pillar components off all you do is follow the cable that possibly snaped and its self explinatory from there. Dont forget to hook the cable front the cable tensoner back upto the seat, or your seatbelt still wont move.
seat belt problem jybute BMW OEM Parts Department DIY's & FAQ's 1 02-13-2006 12:24 AM
How to remove the rear seat (movie) Cambridge E12, E28, E34, E39, E60 1 01-29-2006 11:24 PM
BMW Belt I will make Spieluhr United Off Topic  **FOR MEMBERS ONLY** 25 09-21-2005 04:08 AM
Help removing A/C belt projal147 E36 2 05-26-2005 04:00 PM
Fan Belt Joey E21, E30 7 04-18-2005 06:38 PM
