Old 03-25-2006, 10:48 AM   #1
jybute
jybute's Avatar
Your Ride: 2006 330xi, 2007 X5 3.0, 1991 318is
small vibrations
so i recently did a bit of front end work to my car, ( lower control arms and stabilizer links ) and lately I have noticed a small amount of vibration coming from the rear end, but this only happens when the car is cold, and under acceleration. I took it to a mech. and he doesnt see anything wrong with the rear end, but he did suggest i cahange outer tie rod ends, thrust rod bushings, and an alignment. Those would explain the vibration i get at freeway speeds. but what about the vibs from the rear end? anyone of you guys ever experience this before?
I should also note that I just did a diff service on the car, including outer axle seals, with synthetic diff fluid, but this problem has just crept up.
Old 03-25-2006, 11:03 AM   #2
Rate My Car: 134 / 340
Check your "guibo" joint. (rubber flex connector on driveshaft) just a suggestion.
Old 03-25-2006, 11:06 AM   #3
jybute
jybute's Avatar
what am i looking for? cracks? Not crack... cracks?
Old 03-25-2006, 11:12 AM   #4
Storamin
Storamin's Avatar
Title: Road Kill
Cracks and deterioration in the rubber. If it's really bad, you'll see strands coming out of it.
Old 03-25-2006, 11:16 AM   #5
jybute
jybute's Avatar
why wouldnt a mech. look for this? man, i guess if you want something done right you have to do it yourself.
Old 03-25-2006, 06:08 PM   #6
Storamin
Storamin's Avatar
Title: Road Kill
Because most mechanics don't want to spend more time on a car than they absolutely have to.
From the rear end it could also be the rear trailing arm bushings. Maybe that's what he means by thrust bushings. They're known to go out after 100k or much sooner.
Small laptop Rooz Geek Chat 27 01-19-2006 07:28 AM
Some small mods... donald1476 Bimmer Showroom 26 12-18-2005 05:00 AM
Font SIZE....too small and text links scattered... delmarco Site Feedback 11 04-24-2005 12:57 PM
