Old 02-22-2006, 10:04 PM   #1
nightdevils
nightdevils's Avatar
Rate My Car: 158 / 337
Your Ride: 2001 BMW 530iA
question on break-in procedure
So the manual says, upto 1200 miles, drive at varying speeds, and not to exceed 4500 rpm. Does anyone know the exact reason for limiting the RPMS? My bro's rx8 doesn't have rpm limitation for break-in procedures, and wondering why the difference.
Old 02-22-2006, 10:05 PM   #2
nightdevils
At the same time, aeroplane engines recommend going full throttle (for the piston kind) for break-in.
Old 02-22-2006, 10:11 PM   #3
BMWLotAttendant
Title: I Drive EVERYTHING
Your Ride: 1997 Camry CE
The new M5 has a break in procedure too....no going faster than 130mph for the first 1200-1500 miles.
I think it is to slowly make sure things are running right...and break stuff in.
Old 02-22-2006, 10:23 PM   #4
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
Sometimes nice things need to be broken in.
Old 02-22-2006, 10:30 PM   #5
Rate My Car: 84 / 337
The variation of engine speed is to keep the engine from forming rev habits that would happen if it spends too much time at any one speed. With planes that run the exact same revs for long periods, this is not an issue.
Old 02-22-2006, 10:40 PM   #6
nightdevils
True, how about the limitation of the rev to be less than 4500 rpm. Why that specific RPM. If they wanted to allow varying speeds, shouldn't they also also for variable RPMs without limitation?
Old 02-22-2006, 10:45 PM   #7
Simply because the speeds above 4500 are too high for a new engine.
Old 02-22-2006, 10:46 PM   #8
komodo
komodo's Avatar
Title: Administrator
Rate My Car: 71 / 337
Your Ride: 1995 M3
All the parts are smooth and new, I'm guessing it's to wear them down a bit in the correct patterns to make them work together smoother. (completely a guess though, no factual backing)
Old 02-22-2006, 11:04 PM   #9
Storamin
Storamin's Avatar
Title: Road Kill
http://www.mototuneusa.com/break_in_secrets.htm
End of story, nuff said
YMMV... literally.
Old 02-22-2006, 11:17 PM   #10
nightdevils
Storamin, thats exactly what I was looking for My brother mentioned something similar but I wasn't sure. Thanks a million!
Old 02-22-2006, 11:56 PM   #11
Rate My Car: 137 / 337
That "break in procedure" is so the piston rings seat and develope a slow wear pattern. Also so the internal bearings all seat. (amongst other things)
Old 02-23-2006, 12:15 AM   #12
nightdevils
Here's the million dollar question (the whole para ): so what if my car wasnt properly "broken" in to? I am saying this b/c this is a 2001 e39 with 26k miles. The driver more than likely didn't drive the car that often, and I wouldnt be surprised if he didnt follow the "varying speeds" seriously. My first order of business after I get the car back from the body shop is to take the car in to the dealership and get the gaskets changed-> oil leak (bmw tech said that before we got rear-ended). I will also take a sample of the engine oil and send it in for analysis. But I am wondering if there's anything that could be done to fix bad break-in scenarios.
Old 02-23-2006, 12:19 AM   #13
The biggest concern if you suspect bad break in, is if you have an oil burning problem. Gaskets leaking are a syptom of doing alot of sitting, the gaskets dried out. I'ld only be concerned if you have engine bearing noise or oil burning. Have your "tech" do a compression test when you have it in.
Old 02-23-2006, 12:21 AM   #14
Rate My Car: 183 / 337
yeah, and a bad break in wont show anywhere near 26K.. much higher up it may show
Old 02-23-2006, 12:38 AM   #15
nightdevils
I see, will tell the tech to do the compression test. BTW any other things I should check for .. for a car that had been sitting for a long time?
Airplane Flight Question komodo United Off Topic  **FOR MEMBERS ONLY** 105 07-27-2007 09:35 AM
E30 Brake Pad Changing Procedure nick_318is BMW OEM Parts Department DIY's & FAQ's 6 10-14-2005 05:36 PM
Computer question Nattles Geek Chat 16 09-07-2005 07:28 PM
rear bumper question. EcianIce E46 3 05-05-2005 10:16 PM
