Old 04-16-2005, 02:16 PM   #1
Torque
Torque's Avatar
Title: Lawl.
Your Ride: '00 Impreza
E34: What will break ?
Courtesy of www.bmwe34.net:
1. Self locking bolts on cam oil spray bar. Look for worn camshaft lobes from this.
2. Hood & trunk gas lifts.
3. Front suspension: tie rod ends, ball Joints, possibly struts and bearings. Thrust arm bushings.
4. Sway bar links and bushings. Rear differential mount and rear subframe bushings.
5. Fan clutch on water pump.
6. Brake rotors, pads, sensors, timing belt and tensioner (M20), brake or clutch switch.
7. Exhaust components, usually muffler. O2 sensor.
8. Heater control valve, Fan speed control whether sword or resistor pack. A/C compressor.
9. Differential speed sensor.
10. Clutch, Driveshaft ujoints center bearing guibos.
11. Radiator and hoses. Thermostat.Water pump
12. Doors restraint (the metal bar that stops the door from opening too far) is attached to the very thin metal of the door frame and is starting to fatigue and crack.
13. Gauge cluster, usually capacitors repair for 5.00in parts or purchase 750.00 rebuilt unit.
14. Steering box, excessive play on center, sometimes just an adjustment.
15. Light control module (LKM) repair or replace.
16. Seat cables modified. Arm rest repair. Door panels above armrest coming unglued.Sunroof drains plugging and sunroof seals out of aligment.
17. Wheel bearings front and rear, usually front first. Sealed unit you must buy the entire hub. Cv boots on rear axles.
18. Oil canister (oil filter housing) valve is failing. This is BMW mistake. Canister needs to be changed (M30 engine only).
19. Fuel pump relay and main relay.
20. Glove box latch.
21. Excessive play in shifter handle on automatic. Adjustment.
22. Automatic transmission depending on maintenance.
23. Timing chain tensioner.
24. Fuel pump.
25. Occasionaly an oil pump. Not that common.
26. Occasionaly a headgasket. Common on M30 engine with the coolant that had not been changed every 2 years.
27. After 400k miles, you should change your engine :-)
Old 04-16-2005, 11:59 PM   #2
528man
great find
1997 528i
Old 04-18-2005, 10:51 PM   #3
munichman
and nikasil V8s...
Old 05-10-2005, 05:01 AM   #4
cainchapman
cainchapman's Avatar
Rate My Car: 133 / 329
Your Ride: 1995 540LE
Nikasil is only a problem for you guys in the US. We never had a problem with our Nikasil blocks due to our fuel! Nothing wrong with my M60
Old 05-14-2005, 04:51 PM   #5
4themasses
Is that all......for a minute I was worried....
Move Over for the Executive X-press
89 525i - BAV AUTO Springs, 17" Borbet, X-drilled rotors, Racing Dynamics Cat Back
98 328is - Dinan Carbon Fiber CAI, 18" HP rims, many mods sitting in basement yet to come!
Old 05-17-2005, 04:26 AM   #6
sp0rk
Rate My Car: 67 / 329
Let me see what I have done on that list...
Wait a minute... Let me see what I haven't done on that list... lol
blah.
Old 05-17-2005, 04:28 AM   #7
sp0rk
oops
1990 525iA | 28 HP at the crank (feels like it) | H&R Springs | HID lighting | Painted side skirts and bumper bottoms | Shadowline trim | 17" Mak Matrix wheels | CAI | Chip | 20% Rear tint | Clear front turn signals
see pics at my cardomain site:
http://members.cardomain.com/sp0rkage
Old 05-20-2005, 06:21 AM   #8
kiwi535
That look's awfully familiar....E34.net????Hell a lot of that stuff will go wrong on ANY car....
ooops my bad,I just noticed the aknowledgement
Old 05-01-2006, 09:57 AM   #9
euro driver e34
Name: euro driver e34
Your Ride: 1994 525i
It seems like the U.s. models have all of these engine and suspension problems? Unlike my car which seems to have minor interior electrical problems. But the hinges on the glove boxes are junk it drives me nuts!
Old 05-01-2006, 10:09 AM   #10
Rate My Car: 136 / 329
Suspension -> shitty US roads
E34s have clips that easily come unclipped (on the back side) - super easy fix. Open, align bottom front and feel for molded clips on back and give it a shove. They line right up and clip on small crossbar in back.
Old 05-01-2006, 12:31 PM   #11
Storamin
Storamin's Avatar
Title: Road Kill
no stock bmw suspension is good. replace immediately.
Old 05-01-2006, 03:42 PM   #12
dinan540
dinan540's Avatar
^^^^agreed.
540i with some mods
Old 05-01-2006, 03:55 PM   #13
Storamin
Storamin's Avatar
Title: Road Kill
haha
Old 05-02-2006, 04:05 AM   #14
cainchapman
The M5 package is a great stock package. Especially with EDC, you can travel in comfort on trips and flick it to stiff for track days and fast twisty stuff.
It is not as good for the track as a well designed package. But it offers a great compromise between both extremes.
Old 05-02-2006, 05:05 AM   #15
euro driver e34
Ya, I know all about the clips. But after a year and half the still give me problems. See to get on a military installation you have to get in and out of the box quite often. and I seems to that people like to pull on like it is a pulls out or let it drop. Don't worry, after that I make them walk.
E34 ice racing jybute E12, E28, E34, E39, E60 4 10-20-2005 02:55 PM
Bought an e34 catalyst E12, E28, E34, E39, E60 14 10-05-2005 04:06 AM
E34? jybute E12, E28, E34, E39, E60 26 09-22-2005 12:13 AM
Sik e34 M5 !!! 1129 bhp Kicks ass of nissan Silvia with headstart defkon99 Video and other Multimedia 7 08-21-2005 03:41 AM
E34 M5 in the House 91m5 M5 13 08-07-2005 08:22 PM
