Old 05-02-2006, 05:12 AM   #16
euro driver e34
Name: euro driver e34
Your Ride: 1994 525i
Oh, one more thing only, difference in the the rod types is the thickness to reduce the amount of wear with the higher speeds. A U.S. road has 11 inches of thickness compared to 26 inches on an autobahn. Road quality is about the same except that little fact. So a suspension upgrade is a good thing no matter where you are at.
Old 05-02-2006, 11:54 AM   #17
BMWLotAttendant
Title: I Drive EVERYTHING
Your Ride: 1997 Camry CE
OT: Speaking of Torque, where is he?
Old 05-02-2006, 12:55 PM   #18
zeaq328i
zeaq328i's Avatar
Title: BMW 328i
Rate My Car: 307 / 329
^^Other forum. hehe..
.BMW 328
Old 05-02-2006, 01:24 PM   #19
Storamin
Storamin's Avatar
Title: Road Kill
torque left.
Old 03-23-2011, 05:34 AM   #20
Remo
Your Ride: 1990 520i
A GREAT article
I happened onto this article just searching the net. Very interesting info, especially about the water pump and why it should be replaced. Seems he runs a repair shop.
The BMW M50 engine series is a very durable powerplant. The frequency of actual failure is very low considering the number of these cars that we service. Even with repeated bouts of overheating, they seem to survive well. The least common cooling system failure is the head gasket, or at least leakage in the head-to-block interface. In this article, I’ll cover the diagnosis, repair and prevention of these failures, but it will be up to you to convince your customers that regular maintenance and inspection is the only way to prevent expensive failures.
COMMON PROBLEMS
The events leading up to a head gasket failure can almost be plotted on a graph of typical events. The customer complains of overheating, but the coolant level doesn’t drop. The fan, belt and hoses all appear OK, and thermostat function tests fine with a non-contact temp probe. The engine temperature spikes at times, but then is normal. The engine does or doesn’t overheat at idle, but the temperature climbs quickly at higher engine speeds.
On most M50 engines, the water pump impeller installed at the factory is plastic. For whatever reason, the impeller separates from the shaft or disintegrates and the water pump no longer pumps. In the first case, with the impeller loose, especially with the engine at operating temperature, diagnosis can be especially difficult. Just when you think there is no flow, some coolant starts to move and everything tests OK, temporarily.
Another problem along this same line is that the auxiliary coolant pump for the heater system can circulate enough coolant to provide cooling at idle, but not at higher engine speeds.
Then the problem increases in frequency and intensity, coolant is lost, a leak starts at the plastic thermostat housing or, in a worst case scenario, the upper radiator hose blows off, due to failure of the plastic outlet neck (sometimes caused by over-tightening). Then, a series of overheating events culminate with a severe loss of coolant, a misfire and a customer with a very red face.
At this point you can’t pressure-test the system, a block test may or may not have been conclusive and there are still the questions about the water pump, fan clutch, auxiliary fan and switch and a stuck thermostat. It’s usually only after all of these other possible overheat sources are eliminated that a head gasket failure is suspected or indicated.
So now I know why it was overheating. This guy just saved me some bucks.
"War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling which thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature, and has no chance of being free unless made or kept so by the exertions of better men than himself."
John Stuart Mill
E34 ice racing jybute E12, E28, E34, E39, E60 4 10-20-2005 02:55 PM
Bought an e34 catalyst E12, E28, E34, E39, E60 14 10-05-2005 04:06 AM
E34? jybute E12, E28, E34, E39, E60 26 09-22-2005 12:13 AM
Sik e34 M5 !!! 1129 bhp Kicks ass of nissan Silvia with headstart defkon99 Video and other Multimedia 7 08-21-2005 03:41 AM
E34 M5 in the House 91m5 M5 13 08-07-2005 08:22 PM
