91 525i
i have a 1991 525i, i do all the maintenance myself and even some of the more complicated stuff. i have run into a problem that so far i have yet to find a way to fix. the car runs good till i get to about 2500 rpm then it spits, sputters and acts like it is running on 4 cylinders. does anyone have any ideals?
Have you checked all your vacuum lines and hoses? ICV?
I didn't see anything, but i could take a lot closer look. Would it need to be a major leak?
Even a very thin crack or tear could cause idle issues.
Ok, thanks. will take a lot closer look.
I checked and replaced a ICV hose and took off and closely inspected the other vac hoses. No change. I have also changed spark plugs, coils, injectors, o2 sensor and fuel filter. I did a fuel pressure test and at idle i had 41psi. I also swapped out the check control and DME without any changes. Oh i failed to mention that the car runs great till it's been at operating temp for about 20 mins then it starts acting like it does.
thanks for the ideals. it turned out to be a fuel pump.
| All times are GMT -5. The time now is 05:28 PM. |
