Old 08-03-2010, 08:39 PM   #1
mdrexusa
Your Ride: 2000 528i
Angry P1421 & P1423 Codes
I have a 2000 528i w/ 118000 Miles. I have replaced the air-pump, air-pump valve & the relay. The pump runs but the ck engine light comes back on after 4 to 6 starts. I have a code reader and it always shows P1421 & P1423 as the codes. ANY ideas??? I'm about to pull the rst of my hair out. Any help will be appreciated.:
Old 08-10-2010, 02:17 PM   #2
mdrexusa
Still no suggestions. I could really use some ideas here. Thanks
Old 08-16-2010, 09:41 AM   #3
Big Evil
Big Evil's Avatar
Both secondary air system codes (bank 1 and 2), are there any splits or leaks in the hoses? You may want to smoke check the system.
Old 08-16-2010, 04:56 PM   #4
mdrexusa
The main hose from the valve to the pump was replaced because the other one was cracked. I even replaced the vacuum line from the vacuum system to the valve. I will try the smoke test though and thanks for the reply. mdrexusa
Engine codes - anybody speak "dealer?" volvodefector79 E36 4 05-25-2010 08:11 PM
Australia error codes fenlux E36 1 03-31-2009 09:58 AM
OK - getting codes, CHECK ENGINE light works, but it's not on! volvodefector79 E36 1 11-13-2007 05:46 PM
Trouble Codes Spieluhr E36 5 05-29-2005 06:29 PM
