Old 10-14-2007, 01:29 PM   #1
bmw535i
Your Ride: BMW M5 E39 BMW 635csi 1986 BMW M535i 1986 BMW 530d BMW 540i Touring BMW 730i BMW 325i E30 Cabrio
Smile E39 auto gearbox fluid change
I have a 1997 E39 535. I need to check the fluid level of the auto gearbox. I am not sure how to do this. I think that the gearbox is filled with the bmw lifetime fluid, but i don't know how to check the level and how to change it.
Can anyone help?
thanks
Old 10-14-2007, 02:21 PM   #2
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 119 / 337
Your Ride: ^^
as far as checking the level there is no easy way to do it. BMw doesnt makea dipstick for transmission fluid.
what you have to do is park the car on a level surface, lift it and take out the transmission oil plug. located on the bottom of the transmission, you cant miss it. I believe its a hex bolt, like 23mm or something.
there is also a drain plug down there somewhere. The way it works is you drain it with from one hole and fill it from the other. The other is designed to overfill when the transmission fluid is good. So...when its filled itll start to spill fluid.
If you swap the fluid use redline. its good stuff. also you will need a hand fluid pump to pump the fluid into the transmission.
this is assuming your transmission is like most other BMw transmissions.
DIY: Bleeding BMW Brakes mullethunter3 BMW OEM Parts Department DIY's & FAQ's 15 11-17-2010 03:11 PM
E36 Automatic Transmission Fluid Level Check Chris E36 4 09-03-2007 10:42 AM
E30 transmission fluid change and gasket change mzbmw325i E21, E30 4 08-03-2007 04:03 PM
BMW Tranny Fluid DEATH2000 E36 13 01-08-2006 04:30 PM
Something New At Premium Auto Care Dwayne@PremiumAutoCare Detailing and Cleaning 1 09-19-2005 11:55 AM
