Old 04-23-2007, 06:09 PM   #1
tezmanian
Your Ride: 1995 530
03 540 Electrical Failure
5 days after 3-year anniversary dealer check-up and warranty expiration date, car wouldn't crank. Towed to dealer. Dealer replaced battery and tested charging system; said A-OK. 5 miles from dealer after picking up car, battery light came on. Returned to dealer. Dealer now says alternator has failed. Dealer replaces failed alternator. Did the failed alternator cause the battery to fail, or did the failed battery cause the alternator to fail???
Old 04-23-2007, 06:14 PM   #2
mullethunter3
mullethunter3's Avatar
Rate My Car: 163 / 337
I don't know if scenario #2 can happen... I've had at least 10 dead batteries in this car, soooo probably not. I would bet on your alternator killing your battery.
Old 04-23-2007, 08:44 PM   #3
Rate My Car: 137 / 337
More than likely it was the alternator, but it could go both ways. A weak battery would make the alternator work harder also.
electrical jybute E36 6 05-10-2010 02:14 PM
Just finished clutch repair, now electrical system won't charge? bearcat77070 E36 4 02-26-2007 06:24 PM
RSM failure and Subframe failure 94bmw325i E36 22 10-25-2006 10:28 AM
Need some ideas beem Non BMW General Automotive Discussion 6 10-02-2006 07:31 PM
rear blind help zx7rhitch E36 12 05-30-2006 02:11 PM
