Old 04-17-2007, 08:00 AM   #1
eightynine535
Your Ride: 1989 535i
fog lights problem--E34
my foglights do not turn on anymore. the driver's side used to work and i kept getting that annoying chime. after i checked it out i saw the wire to the passenger side foglights had broken of the harness on the back of the foglight.
I checked the bulbs and they are fine, I also changed the fuse and reconnected the harness. but now none of them tun on........and that chime is getting annoying! can anyone tell me where the relay to the fogs are located so I can check if it is bad?
Old 04-18-2007, 08:19 PM   #2
eightynine535
anybody?
Old 04-18-2007, 08:42 PM   #3
theSMELSINATOR
theSMELSINATOR's Avatar
Your Ride: 1990 325iX
i'd bet you could find it here:
http://www.bmwe34.net/
Old 04-20-2007, 05:23 PM   #4
eightynine535
tried there before posting and found nothing relating to my problem.
Old 04-21-2007, 04:46 AM   #5
cainchapman
cainchapman's Avatar
Rate My Car: 130 / 337
Your Ride: 1995 540LE
Have you removed the light unit and checked the connections for power? I'd do that before going looking for relays.
If you have no power at the connectors (just push in type), then you need to look in the fuse box (where the relays are too).
But they are notorious for poor earths and connections. Just try pulling both units out. Clean the terminals and replace them (assuming you have voltage there)
Old 04-21-2007, 08:34 AM   #6
eightynine535
ok i'll try that. if it does not work...i.e. I have no voltage and the fuse is good, which relay operates them?
Fog Lights JJs318 E36 2 11-06-2006 06:26 PM
fog light problem HELP! Tochenzo Lighting 6 10-10-2006 11:32 PM
e34 fog lights head lamps jybute E12, E28, E34, E39, E60 0 02-09-2006 01:10 PM
Fog lights Rooz E36 44 06-27-2005 07:47 PM
