E12, E28, E34, E39, E60General discussion and technical help for all year 5 series cars.
Your Ride: 1989, 525I
Series ?
I just purchased a 89 525i. and I need to know if there are diffrent series of the model.Its my first , from VW to Cadi's )
The reason I need to know this is because I want ot re-set my service engine indicator lamp (without using the tool) so I want to make sure that I jump the right pins on the computer reset.
I am a new member of this group and I look foward to sharing my technical knowledge with everyone
you also might check out www.bmwe34.net - alot of good basics to get you started. NOTE: 1 weak point you might want to address is the timing belt & waterpump - 2 weak spots the early e34s had.
