-   E12, E28, E34, E39, E60 (http://www.unitedbimmer.com/forums/e12-e28-e34-e39-e60/)
-   -   white smoke on startup (http://www.unitedbimmer.com/forums/e12-e28-e34-e39-e60/10106-white-smoke-startup.html)
swampdonkey 01-24-2007 05:56 PM
i have recently been experiencing white smoke on startup. not loads but not normal. only appears when i start up, not when driving. performance not affected at all. doesn't happen all the time though. sometimes i can start up and everythng is fine, other times i get a plume of smoke. any ideas?? help!!!
xsperf 01-24-2007 05:58 PM
two things, coolant, or a ton of unburnt gas, do you have to crank your car for a WHILE before it starts up?
witeshark 01-24-2007 06:01 PM
I have read that this can be normal on cold startups from a rich mixture
swampdonkey 01-24-2007 06:35 PM
starts first time. no problems. like a brand new car. done 105,000 miles. smells burnt. don't think its oil though
swampdonkey 01-24-2007 06:39 PM
also. it isn't always from a cold start. can be turned off for only 30 mins and does it. strange
xsperf 01-24-2007 07:48 PM
ouch, may be your coolant which would really suck, check yoru coolant level, unburnt gas can cause it, however too rich will cause black smoke
