Old 01-23-2007, 01:07 PM   #1
abdallah_n
Your Ride: 1990 535i
Lightbulb battery tip
hey guys,
just finished my exams and had to celebrate first with my lovely car for a bit, but she was a party pooper, the damn battery is dead . i was expecting it anywayz since the car was parked for 2 weeks and the battery is too old and need replacement. soo, i just wanna ask wut battery should i buy, like wut rating (12V ....)? and is there a recomended brand for those?? btw, the car is 1990 535i.
thnx
Old 01-23-2007, 01:31 PM   #2
Rate My Car: 137 / 337
If there's an Autozone nearby to you you might check out their Duralasts - in my E34 I have their 1000w monster that cost $70 and it's been reliable so far 3+ years and mine sits alot.
Old 01-23-2007, 01:33 PM   #3
mullethunter3
mullethunter3's Avatar
Rate My Car: 163 / 337
Get the most CCA (cold cranking amps) for the money. It's totally worth it. Not Cranking Amps, cold cranking amps.
Old 01-24-2007, 09:46 AM   #4
abdallah_n
Thumbs up
thanks guys, ill look for one of those.
thnks for the help again
Old 01-24-2007, 10:14 AM   #5
beem
Your Ride: '00 540/6 Dinan S2(sold), '90 525i/5, '01 Audi S4
i used to look for the real nice batteries such as Optimas, etc., but in the end I bought an AutoZone one, and it worked just perfect. No complaints at all
...let's go to the highway!
Member of the Spririted Driver Club.
Old 01-25-2007, 07:46 PM   #6
Rate My Car: 106 / 337
Okay, so my battery just died, and went to look for a replacement . . neither Sears, Autozone, nor Pep Boys had an equivalent. They're saying it's a dealer item. Anyone run into this crap?? Might it be because my car is a '92 M50?
Old 01-25-2007, 10:23 PM   #7
Dski, take the EXACT dimensions of your battery, note the sides (positions) of your +/- posts and go into Autozone and pick out the battery you need by size and the highest cold crank you can get for the money you want to spend. Their newer catalogs/computer look up systems SUCK and they overlook stuff that isn't popular sales items. I called a local Autozone & the guy said they only offer the "Optima" line for your car and they're $160+ which is just bullshit - just match the EXACT size & Post config & you'll be ok
Old 01-26-2007, 05:18 AM   #8
Yea, I believe it's either group 41 or 49 that fits. The problem is the vent tube- it's either nonexistent or on the wrong side
Old 01-26-2007, 07:44 AM   #9
If it's a long low - yea it's group 49 (I'm glad you brought it up - I went back in my records to check my oe purchase date 3 years ago - group 49 Duralast battery at Autozone $64.99 w/exchange 1000CCAs)
Old 01-26-2007, 12:29 PM   #10
I decided not to screw around with trial & error and trying to retrofit the vent tube especially during this freezing cold snap, so I just got back from the dealer . . problem solved, and I was pleasantly surprised- it was $132, reasonable enough for me.
Old 01-31-2007, 01:36 AM   #11
Eagle
Eagle's Avatar
Rate My Car: 66 / 337
Your Ride: 92 BMW 525iT
Dudesky, I just replaced/upgraded the one in my 92 525iT from a type 48DL installed by a PO that was failing (free upgrade for battery failure, thanks AZ manager!). $70 as mentioned.
The duralast type 49DL fits, though it is tight. I left the parking lights on the other afternoon for two hours and it started up like nothing had been left on (raining and forgot to turn off after getting the boys and all their gear out). It comes with the vent tube adapter.
never mind.
Old 01-31-2007, 01:48 AM   #12
cainchapman
cainchapman's Avatar
Rate My Car: 130 / 337
Your Ride: 1995 540LE
Check with BMW for an OEM one. My original battery lasted 9 years. Due to this, I replaced it with another. Costs more, but cost amortised over the lifetime is lower than a cheap battery.
The 540 battery is under the back seat though, which keeps it well away from heat, which is a batteries worst enemy.
Old 01-31-2007, 02:07 AM   #13
Eagle
Eagle's Avatar
All 92+ have it under the backseat.
Old 01-31-2007, 07:07 PM   #14
abdallah_n
true, except for tdi models i guess
Old 01-31-2007, 07:59 PM   #15
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
Some are in the trunk.
battery problem V-tecKILLAH E12, E28, E34, E39, E60 3 03-07-2007 04:07 PM
Check Your Battery Compartment 3050rpm E36 4 09-15-2006 07:06 AM
Mounting Battery newest2002tiiowner 2002 1 08-28-2006 05:54 AM
I think my battery done for. What should I replace it with? delmarco E36 21 09-17-2005 11:20 AM
My battery is dead Rooz E36 24 05-24-2005 11:30 PM
