Old 01-13-2007, 10:53 PM   #1
jybute
jybute's Avatar
Antifreeze?
I have an'89 535i And would like to flush the coolant this weekend, and need to know what type of antifreeze is "BMW aproved".
Old 01-13-2007, 11:09 PM   #2
3050rpm
3050rpm's Avatar
This past summer I went with Preston Premixed Quick Fill, 5 yr./150,000 miles (although I won't keep it in that long). $9.99 a gallon. Seems to be the latest formulation for anti-freeze. See the Preston web site for further information.
Old 01-14-2007, 07:19 AM   #3
Rate My Car: 106 / 337
I use Zerex G05.
Old 01-14-2007, 02:06 PM   #4
bimmerZ5
bimmerZ5's Avatar
Rate My Car: 22 / 337
Your Ride: 2003 BMW 530i, 2001 BMW Z3 3.0i, 1995 Toyota Previa S/C
Prestone Yellow should be fine. save yourself the time and just get the 50/50 pre-diluated bottle. walmart is the cheapest i've found them.
Old 01-14-2007, 02:43 PM   #5
Tinkerbell
Your Ride: 1993 318i
My car is leaking anti freeze very slowly...its probably just a cracked hose but...My car is also now not starting...are they related?
It is turning over so the battery has enough juice...at least that is what I have been told. Would anybody have any idea as what the problem could be? Could it be my alternator packing it in as I have stereo equipment in it and I just had an automatic starter with alarm installed about a month ago...perhaps that was too much for my alternator.
Or could it be that its -5 here and my car just doesn't like the cold...is there a plug somewhere on it that we can plug in and heat up the engine block?
Old 01-14-2007, 06:19 PM   #6
Rate My Car: 137 / 337
those are pretty vague descriptions. Where's the leak exactly dripping (at least a point under your car - and please don't say under the front) and for not starting there's ALOT of possibilities - turning to slow, low voltage (not enough current for turning the car + starting) bad gas, frozen fuel lines, the list is endless. you have to be more exact ... PLEASE! When was the last tune up? fuel filter change? maintenance? we need more info if we can possibly try to help you & save you from the wolves at service places. If all else fails - have it towed to a local dealer - it sounds like your car has a handful of problems and they are best equipped to address all of them.
