Go Back   United Bimmer Community - BMW Forum > UnitedBimmer-General BMW Topics > Detailing and Cleaning
Detailing and Cleaning Sponsored by: Autogeek.net
Discuss waxing, cleaning, detailing and everything in between here to keep your bimmer looking its very best.
Old 03-14-2006, 08:19 PM   #1
///Menace328i
Your Ride: 1998 328i
Engine Compartment Cleanliness
After looking at this car's engine compartment...
mine needs to be cleaned... bad!... How do you do it? I have used that grease cleaner spray and after using water to rinse it off I ended up with several shot sparkplugs.. nooooo not in my bimmer, but on other cars I have so I decided not to use that stuff ever again... and yes I did cover all the esential electrical parts. Any suggestions?
BTW i hope the owner of this car doesn't mind me using his sex machine's picture.
Redefining Ballerism!
Old 03-14-2006, 08:28 PM   #2
Rate My Car: 136 / 329
Old 03-14-2006, 08:49 PM   #3
DEATH2000
DEATH2000's Avatar
Rate My Car: 123 / 329
I use armor all, those wipes are the shit.
Old 03-14-2006, 10:27 PM   #4
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 128 / 329
Your Ride: ^^
you know while on the subject, my valve cover has lost its luster and started to chip off what looks like a protective coating. Anyone got info on refurbishing it, or how to clean that. Degreaser wont help that i dont think.
Old 03-14-2006, 10:30 PM   #5
Numark318i
Numark318i's Avatar
Your Ride: ^^
on a side note it amazes me how similar the engine bay of the e36 looks to the E30. The e46 looks slightly different. I guess that just means they had the right idea the first time.
Old 03-14-2006, 10:40 PM   #6
doughboyea
doughboyea's Avatar
Your Ride: 2007 Acura TSX
What?
Current Ride
2007 Acura TSX w/Navi
Past rides:
1989 Mercedes 190E 2.6
1980 Mercedes 240D
Old 03-14-2006, 11:10 PM   #7
Numark318i
Numark318i's Avatar
Your Ride: ^^
compare a E30 engine bay to an E36.
Old 03-15-2006, 12:43 AM   #8
Rate My Car: 173 / 329
that hosing down stuff, even if you cover up all your electronics, ull probably get some water in there, and consering your arent supposed to go to a carwash with an e36 b/c they are notorious for getting water into the ECU, i would just use a rag and same engine decreaser, but wipe it off, dont hose it off(wipe it off with anything, including armor all wipes, like death said)
also, WD40 is a neat trick, it doesnt clean it, but it makes it look amazing
Old 03-16-2006, 12:32 AM   #9
Rob
Rate My Car: 93 / 329
Yup. Take a rag and spray some engine degreaser on it, then start wiping. Works well and you never have to worry about killing electronics. After the degreaser, do the same with some engine dressing, or WD40 I guess, and it will shine like original. NEVER use Armorall on anything. It may clean well but it will chew through connectors and rubber gaskets/trim. It's just not worth it IMO.
As for my valve cover, I sanded and sprayed it black while doing a valve cover gasket job. It made a world of difference compared to the peeling cover.
Old 03-16-2006, 12:40 AM   #10
Rob
They filled the e46 with a bunch of plastic covers so it scares the owner, so they don't do their own work on it and take it to BMW. BMW likes doing that. When was the last time you saw a surpentine belt diagram in the engine bay of a BMW?
Old 03-16-2006, 12:56 AM   #11
Rooz
Rooz's Avatar
Rate My Car: 7 / 329
Your Ride: 2003 M5
I think I'll burn all my plastic covers
Doubt this is a 330.. but u get the idea...
Pretty clean though
VIEW MOD LIST & PICS
Originally Posted by Gregg
Old 03-17-2006, 12:38 PM   #12
Rob
Pretty clean though
Um, right hand drive?
Old 03-17-2006, 04:18 PM   #13
DEATH2000
DEATH2000's Avatar
^^ What d'ya know... it is right hand drive
Old 03-17-2006, 09:57 PM   #14
Rooz
Rooz's Avatar
Your Ride: 2003 M5
Ok.. how can you tell?
Old 03-17-2006, 11:31 PM   #15
look at where the brake booster is and where the master cylinder is
Considering Buying An E30?Upgrades?Differences? spiff E21, E30 14 02-07-2012 11:53 PM
Alpina 318i....explain this to me delmarco E36 62 01-28-2010 04:14 AM
Engine Differences htp.bmw E21, E30 4 09-19-2007 11:34 AM
I finished the engine swap htp.bmw E21, E30 7 06-21-2005 12:33 PM
2.5l Engine, 2.8l Cams, and more for Sale jrhaile Bmw Cars For Sale/Wanted 7 04-28-2005 09:54 AM
