Car Audio and Electronics
Your Ride: 94 325is
Taking out Headunit 94 325is
I was wondering if anyone had intrustions/pictures on how to take the headunit out of a 325is.. It is not a factory headunit.. i just want to take it out so i can install my new system.. thanks
a lot of times they come with tools that slide in on both sides. they are like cheap stamped metal "pullers". that is if the headunit required a sleeve in the dash for the install. it all would have came with the unit. it does *kinda* matter who makes it.
that silver trim just snaps out,then either use some pioneer "keys" on either side to remove it, or use a very slim screw driver to pop it loose from it's cage
Your Ride: 94 325is
I installed my new system... 1 10inch kicker running off of a profile (baja 700) amp... I didn't want anything over powering and annoying..It sounds great, gave me the extra bass that I had been wanting in the bimmer.. Thanks to all
