Skyler O'brien Now On ITunes
Sponsored by: SKOB on itunes
Old 06-30-2006, 06:01 AM   #1
Rate My Car: 106 / 337
Dual batteries
Anyone have experience with dual battery setups?
My bro-in-law has a conversion van that uses 2 batteries, but the auxilliary battery is missing. I assume the isolator is supposed to keep the two seperate, but I can meter 12v on the auxilliary side where the cables are supposed to connect to the 2nd battery. Which means that voltage can only be coming from the primary battery . . is this normal? I don't wanna hook up the 2nd battery and end up blowing them up
Sorry for the non-BMW post
Old 06-30-2006, 07:23 AM   #2
Rate My Car: 137 / 337
Depending on the ISO yea that's normal. TIP: for aux battery - get yourself a marine deep cycle battery. They're tougher and can take massive amounts of abuse.
Old 06-30-2006, 08:01 AM   #3
Thanks, I wasn't sure . . I'll have to check the cables for the 2nd battery. I'll install an inline circuit breaker or fuse (if there is none)before connecting everything, just to be on the safe side.
Old 06-30-2006, 08:08 AM   #4
notop4me
notop4me's Avatar
Your Ride: 1993 325iC
Yeah, deep cycle is used by most for secondary. These setups are recommended usually for massive stereo systems where a few farads of cap just isn't enough. I've always thought it was in vehicles used in sound competitions only.
Ken
Dodging the tumbleweeds...and roadrunners...and coyotes...but not the rattlesnakes.
1993 325iC Pure stock, uh, except for the MOMO Cobra shift knob.
Old 06-30-2006, 09:43 AM   #5
Rate My Car: 183 / 337
are the two batteries parralell or in a series, or are they totally seperate? btw, a lot of times the meter that reads your voltage, its actually the voltage of the charging system, so if your alternator is working and you have a dead battery, it will read 12 volts....
Old 06-30-2006, 06:00 PM   #6
da_bull
da_bull's Avatar
Rate My Car: 148 / 337
Your Ride: 1990 E34 525i
the deep cycle batteries actually dont give up current as fast as a regular batteries. they are designed more for applications where you need a small draw for a long period of time. they also can be drained until dead and are able to be charged back up with less damage to it than a regular battery.
the isolaters are nice because you can totally drain your battery (parking lot, key off time) and start your car to go home.
Old 06-30-2006, 10:11 PM   #7
Rooz
Rooz's Avatar
Rate My Car: 7 / 337
Your Ride: 2003 M5
For Audio systems... I would not recommend it because for one, your alternator isn't made to do this at all....
IF you are doing this for audio, you might want to consider an SVR deep cycle audio battery
VIEW MOD LIST & PICS
Originally Posted by Gregg
Old 06-30-2006, 11:12 PM   #8
This isn't for my car; it's for my bro-in-law's conversion van, which has AC electrical outlets and a breaker box inside, for RV purposes. It was just missing the aux battery, and I wanted to make sure one battery wouldn't simply drain into the other . . guess I'll find out tomorrow
Forget Your Dual Monitor zeaq328i United Off Topic  **FOR MEMBERS ONLY** 20 09-21-2005 03:56 AM
Dual Orion 15" subs devinwwu Bmw Cars For Sale/Wanted 19 06-01-2005 09:48 PM
