Skyler O'brien Now On ITunes
Sponsored by: SKOB on itunes
Old 05-15-2006, 05:54 PM   #1
Negrodamus
Negrodamus's Avatar
Rate My Car: 85 / 337
Your Ride: 92 325is
Amp mounting question
Has anyone mounted their amp on the roof inside of the trunk? If so anyone have any pics of just where they mount their amps cause I have mine mounted behind the rear seat however I cant get it to stay attached.
Negrodamus
Old 05-15-2006, 08:14 PM   #2
Catman
Your Ride: n/a
Mounting amps upside down is usually a bad idea. Heat rises and this puts the PCB at the 'top' ...the heat sinks are designed to draw heat away from the PCB. Having said that ...some amps are more forgiving than others.
There are 10 types of people ...those who understand binary and those who do not.
I love children, but can rarely eat a whole one.
Let us prey.
If money is the root of all evil ...why do churchs beg for it?
Old 05-16-2006, 07:42 PM   #3
Negrodamus
Negrodamus's Avatar
Your Ride: 92 325is
hmm never thought of it like that it makes since I have one of those new sony xplod amps the redesigned them so more than likely I will just mount it to the box
Old 05-16-2006, 08:14 PM   #4
Catman
Your Ride: n/a
If amps are mounted vertically it is 'best' to orient the heat sinks like this:
Not like this
Hope that makes sense.
Let us prey.
Old 05-16-2006, 08:15 PM   #5
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 119 / 337
Your Ride: ^^
I mounted mine on a piece of plywood that i cut to fit behind my back seat in the trunk. I then bought some carpeting, carpetted the plywood and mounted the amp to the plywood. After this i just used thine threaded sheetrock screws(appropriate lenght) and screwed through the board into the metal behind my seats.
Of course my seats dont fold forward like yours do(im assuming?).
Heres a pic, hope it kinda helps.
Old 05-16-2006, 10:17 PM   #6
Rooz
Rooz's Avatar
Rate My Car: 7 / 337
Your Ride: 2003 M5
It also depends what ohm load you going to run it, it's going to run at 4ohm... Who cares, the thing will not really get hot at all. But if on the other hand it;'s going to run at 1ohm or smaller... then IF you mount it under the rear deck or under a seat (somewhere with not as much ventilation) then get some fans or something.
But it all depends on what you going to push it, how hard you'll push them and what ohm load they will run on...
VIEW MOD LIST & PICS
Originally Posted by Gregg
Old 05-17-2006, 04:10 AM   #7
Rate My Car: 137 / 337
I've seen them mounted on the "underside" of the rear shelf (in trunk) using a U shaped shelf. As mentioned earler, heat sinks should always be aimed to pull heat away from the unit. Also check the mfgrs recommendations on positioning - mounting wrong could void warranty or worse yet leave an impression on your mounting surface - 'burnt footprint" - Airflow is your friend...
Old 05-17-2006, 10:37 AM   #8
Rooz
Rooz's Avatar
Your Ride: 2003 M5
Numark318i, what's up with all the white spots in your trunk ?
Old 05-17-2006, 11:33 PM   #9
Numark318i
Numark318i's Avatar
Your Ride: ^^
Silicon. its wha ti used to mount my amp prior to mounting it the way it is....lol
Old 05-18-2006, 09:07 AM   #10
EcianIce
EcianIce's Avatar
Your Ride: Nothing .. for now.
if it were me. i'd stick with the traditional method and bolt it to the rear seat for two reasons.
wires. and wires.
i don't like the idea of the power and ground running up the side of the car to the amp. under the trunk carpeting makes the most sense to me.
second is the signal/power line to the subs. for best efficency you'd want the wire hanging straight down to the amps, to keep it as short as possible. if you stealth the wire .. the length of the wire is inversly proportional to sound quality.
now. just food for thought .. it's just bass anyways. it's not like you're going to demand perfect sound quality.
Member of the First 5 Uniters.
Z3 stereo & amp replacement lanshrk Z Series (Z3, Z4, Z8) 7 05-11-2009 06:02 PM
AMP exploed...or something? Numark318i Car Audio and Electronics 21 02-17-2006 09:11 PM
FS: JBL amp and (2) alpine subs. BIG BASS Spieluhr Bmw Cars For Sale/Wanted 1 07-19-2005 02:08 PM
My Amp caught on fire Antiburn Car Audio and Electronics 4 07-17-2005 05:41 AM
New system setup. Added an amp! EcianIce Car Audio and Electronics 6 04-22-2005 09:37 AM
