Skyler O'brien Now On ITunes
Sponsored by: SKOB on itunes
Old 12-01-2007, 02:59 PM   #1
530isiriusinstall
Your Ride: 2002 530i
2002 530i head unit removal
I am trying to install a sirius starmate 4 into a 2002 530i and cannot for the life of me find anywhere how pull out the stock headunit to plug in the direct fm adapter or any wiring diagrams for where to grab power from once i have got it out
anyone have any good links for me?
here are some pictures http://digitaldeluge.net/bmw.html
Thanks- Jonathan
Old 12-01-2007, 04:33 PM   #2
Rate My Car: 106 / 340
Assuming you don't have the navigation option, remove the volume knob by pulling straight out. You'll find a small torx screw behind there. Once you unscrew it, the MID panel will simply pop off. You will then have access to the CD radio unit's mounting screws.
Most, if not all of what you're looking for can be found at www.bmwtips.com
Old 12-01-2007, 04:44 PM   #3
530isiriusinstall
verry cool thanks
here are some pics http://digitaldeluge.net/bmw.html
ill take more step by step during the install and post them when im done
Thanks -Jon
Old 12-01-2007, 09:44 PM   #4
530isiriusinstall
i have stalled out today on my project i relized after having it apart i need a radio antena adapter http://www.myradiostore.com/sirius/s...ks-40eu20.html
i still have another problem of where to get power from anyone have any sudjestions on what to tap into to get power. should i just tap into the power for the radio?
Old 12-01-2007, 09:48 PM   #5
There's a bank of fuses inside your glovebox. When you open the door, look up.
Old 12-21-2007, 08:27 PM   #6
530isiriusinstall
Bad idea?
Never mind found out how to get the glove box off from the alarm install post. Doh one must always rember to look before they post, sorry.
Old 12-23-2007, 04:34 PM   #7
530isiriusinstall
hum
see below
Old 12-23-2007, 09:32 PM   #8
530isiriusinstall
Pictures
I finaly installed everything here are some pictures.
I decided to take power from the rechargable flashlight and it works fine.
Here are all the parts strewn out all over the table.
Here is where the bracket mounts to under the molding. The yellow stuff is paint that was on the tip of the screw. That was fun to clean up.
Here is a pictures of the radio. Sorry it is such crappy quailty i will take more tomarrow
Here is the antena I am going to use some double sided tape to hold it down
Thanks for everyones help I will post some better pictures this week
Cheers- Jonathan
Old 11-10-2011, 10:04 AM   #9
xecconlight
Your Ride: 2010
Very cool! Thank U.
Info about BMW stock stereos Dudesky Car Audio and Electronics 2 01-15-2007 11:19 AM
Head unit removal QcMarque 7 Series (E23, E32, E38, E65, E66) 4 11-15-2006 09:13 PM
New Head Unit Alpine328i Car Audio and Electronics 26 09-07-2006 12:42 PM
New Head Unit RSF5 Car Audio and Electronics 10 03-09-2006 11:48 PM
New Head Unit Installed + Sirius Rooz Car Audio and Electronics 5 10-11-2005 09:51 PM
