Car Audio and Electronics
Your Ride: 2000 323i Used to Drive 1990 325i
1990 BMW 325i Changing the front speakers, needs some info please.
I am trying to change the front speakers, the back ones where no problem, the front are under the panelling, there is a screw i took out, and that helped a bit, so then i took the paneling off under the steering wheel and there where no screws there to help remove the paneling, please can somone give me some tips on how to change these speakers, thanks
im having a little bit of a hard time understanding what you are saying. i have the same year and if you take out the one screw, the entire kick panel comes off and the speaker can be accessed. i think you have to pull the panel down a little bit to help the top of it clear the dash.
for the driers sid eu have to take off the hoods opener. theres a bolt hold it on. I had the same issue when i replaced my speakers.
so..the hood release is attached to the panel.
Lol Thank You! i Appreciate the reply! Sorry abou the misunderstanding, i meant when i took the paneling off under the steering wheel i thought there would be more screws for the side panels, and there wasn't but it was clarified to me about the hood release Thanks! and have a great Thanks giving,,,,Cheers
Hi, I'm new to this site and I have a bmw 325i 1990 also. The radio on the car that i baught is less than satisfactory and being the car idiot that i am, i need some advice on some speaker and subwoofer setup. Could anyone tell me what size speakers i need that would be compatable and what size subwoofers and where they could go?
yes, if you could post the sizes of the front and rear speakers that would be great, im gonna assume that they are 6". also if i were to get a pair of subwoofers, where should i mount them. I dont think that in the middle of the back seat would work too well but any suggestions would be great.
Your Ride: 1990 E30 325i Cabriolet
the front speakers are 13cm or 5.25" to remove the panel you have to remove the plastic thing on the side they have plastic round things you have to pull the interior circule and then te other thing there are like 4 or5 you remove that and then you can remothe the other thing look at this picture
look number 5 look at this page http://bmwfans.info/ there is everithing about every bmw new and old ones every part accesories etc
