Skyler O'brien Now On ITunes
Sponsored by: SKOB on itunes
Old 05-07-2007, 02:53 AM   #1
wthcly
Your Ride: 328i 1989
How to turn off inspection lights??
Hi,
My husband is going to change my oil, etc and we need to know if the inspection lights (small orange boxes and a clock) will re-set themselves or we have to do something to re-set them?
Help Pleeeaaasse
Old 05-07-2007, 05:28 AM   #2
Rate My Car: 137 / 337
They won't reset themselves, you need the reset tool which sells for about $70 at Bavauto and/or Pelican Parts. There are some DIYs using small jumper wires but you risk causing more problems. Some BMW dealerships will reset them for you if you provide a receipt (for the parts) but many won't.
Old 05-07-2007, 09:06 AM   #3
Undertaker
Undertaker's Avatar
Your Ride: 1991 e34 m50b25
With the ignition switch at (position two) and the engine not running, grounding pin seven (7) of the diagnostic connector for approximately three (3) seconds will reset the oil service lights. Grounding pin seven (7) for approximately twelve (12) seconds will do an inspection service reset.
Old 05-09-2007, 05:19 AM   #4
wthcly
Hi,
Thanks for that. What is the grounding pin seven and where do you find it? Also where is the diagnostic connector? Sorry for being an egg but we need to know as I have always had it out-serviced but this time we will do it.
Old 05-09-2007, 05:39 AM   #5
stevo
Your Ride: 1997 318se Touring
take a piece of household electrical wire strip both ends to expose approx 1inch of bare wire.
remove the lid of the diagnostic connector insert one end of the wire into pin hole #7 and insert the other end of the wire into pin hole #19 turn on your ignition to position 2(do not start the engine) so all the ignition lights are on go to straight the engine bay and remove the wire after 3 seconds that will have reset your service light.
or look here http://www.unofficialbmw.com/repair_faqs/sil.html
Old 05-09-2007, 06:05 AM   #6
Rate My Car: 106 / 337
wthcly: The diagnostic connector is located in the engine bay. But if you have any uncertainty at all about the procedure, DO NOT do it. Although it's quite simple, one wrong connection and you could end up frying your engine's computer (ECU). You can live with the lights not being reset, but you can't afford to fry the ECU. This is why c1apton did not advise you to do it; sometimes if we're not sure of the person's abilities/experience, giving advice can do more harm than good.
Old 05-09-2007, 06:39 AM   #7
stevo
if you are at all unsure or uneasy about doing the above then leave it to a more experienced mechanic /technician, I wouldn't like to think I gave the advice that screwed your ECU.
Old 05-09-2007, 10:09 AM   #8
drz
Title: local dumbass
Rate My Car: 32 / 337
Your Ride: E36 2.8i
Or get the reset tool from Peake or Bavauto. They aren't very costly, and they will certainly to the job right.
Old 05-09-2007, 12:03 PM   #9
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
I picked up a reset tool last year and I must say that it comes in handy and I would rather do it with the tool then risk frying electronics.
Old 05-16-2007, 03:16 AM   #10
wthcly
Thank you everyone
We sorted the light problem and I have since bought a new BMW 325i - yeh!!
Old 05-16-2007, 03:19 AM   #11
I guess that solved the reet tool problem (just a little more costly) "Grats" on the new ride.
E39 - Resetting the service indicator lights e39 bimmer E12, E28, E34, E39, E60 16 03-14-2012 03:38 PM
DIY: Replacing Instrument Cluster Lights mullethunter3 BMW OEM Parts Department DIY's & FAQ's 41 01-06-2008 02:16 PM
e36 ellipsoids intall guide habbie Lighting 5 09-20-2006 11:53 PM
E36 Floorboard Lights Installed! Took All Day/Awesome pictures! delmarco E36 13 08-19-2005 07:31 PM
Can anyone do a carfax report here? htp.bmw United Off Topic  **FOR MEMBERS ONLY** 4 07-14-2005 09:58 AM
