Skyler O'brien Now On ITunes
Sponsored by: SKOB on itunes
Old 04-16-2007, 04:06 PM   #1
325i_GT
Your Ride: BMW 325i 1994
Problems with radio antena of an e36 325i
Hello, this is my 1es time..... so please forgive me.
I'm from Guatemala and I have an e36 325i. My problem is that the radio antena is not working properly.
I ask u if someone can help me, on how to correct this.
Ok, i'm waiting for your info
Old 04-16-2007, 05:08 PM   #2
theSMELSINATOR
theSMELSINATOR's Avatar
Your Ride: 1990 325iX
how is it not working? is it not going up when you turn your radio on? is it not going down? is it just getting bad reception?
Old 04-16-2007, 05:10 PM   #3
Rate My Car: 84 / 337
If it won't telescope up and down, I'd try a little light oil
Old 04-16-2007, 06:09 PM   #4
325i_GT
This isn't a telescopic antena. The car hasn't any visible antena.
And the problem is bad reception.
Thanks
Old 04-16-2007, 06:15 PM   #5
mullethunter3
mullethunter3's Avatar
Rate My Car: 163 / 337
The antenna in an E36 is behind the passenger side C-pillar. The antenna amplifier is behind the driver side C-pillar.
I don't know what's wrong with it, but if you want to get to it, follow the headliner removal link in my signature. C-pillars should be fairly easy to get out, if I remember correctly... it's been a while.
Old 04-16-2007, 08:02 PM   #6
theSMELSINATOR
oops, my bad.
you people and your fancy new cars...
Old 04-17-2007, 09:19 AM   #7
215BIMMER535
215BIMMER535's Avatar
Rate My Car: 127 / 337
Your Ride: '97 328i
are your windows tinted? my reception got pretty shitty after i had mine done
Old 04-17-2007, 09:30 PM   #8
M3killer
Your Ride: 92 325I
there is the antenna box inside the panel in the rear driver side window
Old 04-18-2007, 01:08 PM   #9
mullethunter3
^^^ The C-pillar?
Old 04-18-2007, 05:02 PM   #10
m325
Your Ride: 1994 325
325 Antenna
There is an antenna amplifier behind the driver's side C-pillar. If you have changed your head unit and/or amplifier lately, you may no longer be sending power to the antenna amplifier. If this is the case, you will need to run a wire from your remote amp turn-on lead to the antenna amplifier, and all will be well. (I suffered with bad reception for about a year before figuring this out.)
If you have not made any changes to your in-dash or amplifier, then check for 12V at the power lead of the antenna amp. If there is power, replace the antenna amp. If there is no power, run a jumper line to the amp and see if it works.
Old 04-21-2007, 12:22 PM   #11
325i_GT
Thanks, but that's not so new fancy, but I like it.
Old 04-21-2007, 12:25 PM   #12
325i_GT
Thanks to all of you my friens, I will try to fix my problem. I'll tell you if I can.
Old 10-25-2009, 03:38 PM   #13
macneil
Your Ride: 92 325i
My antenna wire that plugs into my deck doesn't even have a wire in it, it's as iff someone pulled it out.
FM Radio Problems brian97e39 E12, E28, E34, E39, E60 7 06-15-2011 05:14 PM
1990 325i e30 radio help Iceman2k12 Car Audio and Electronics 1 03-23-2007 10:22 AM
e36 325i manual sedan black interior+exterior djlonsk Bmw Cars For Sale/Wanted 1 02-19-2007 09:47 PM
E30 325i Dinan Turbo vs E36 2.8l OBD1 jrhaile Video and other Multimedia 6 10-28-2005 09:02 PM
