-   BMW OEM Parts Department DIY's & FAQ's (http://www.unitedbimmer.com/forums/bmw-oem-parts-department-diys-faqs/)
-   -   DIY E46 Manual Transmission Flush (http://www.unitedbimmer.com/forums/bmw-oem-parts-department-diys-faqs/8894-diy-e46-manual-transmission-flush.html)
Rooz 08-29-2006 09:05 PM
Decide what you'll use. I went with Redline MTL (Manual Transmission Lubricant) Find more about what I used here
So, get your stuff
http://www.blinkfile.com/1375/Fluids.JPG
Then lift up the car (in my case that involved cleaning up the bay so my tech would let me use his lift :doh)
http://www.blinkfile.com/1376/Lift car up.JPG
Locate the transmission and drain plug
http://www.blinkfile.com/1377/Tranny.JPG
Unscrew the drain plug and drain all the dirty fluid out
http://www.blinkfile.com/1378/Tranny Flushed.JPG
Then, tighten the drain plug up, unscrew the fill plug and use a pump to fill the transmission back up with the new fluids.
http://www.blinkfile.com/1380/Filling tranny 2.JPG
http://www.blinkfile.com/1379/Filling tranny 1.JPG
Once you see it overfilling, you'r done, let the excess drain out, tighten everything back up, and call it a day :D
