Go Back   United Bimmer Community - BMW Forum > UnitedBimmer- Tech Talk > BMW OEM Parts Department DIY's & FAQ's
BMW OEM Parts Department DIY's & FAQ's Sponsored by: Advance Auto Parts
Discussion of everything OEM with Advance Auto Parts
Old 12-06-2007, 03:49 PM   #16
johnnybayonne
johnnybayonne's Avatar
Rate My Car: 248 / 337
Your Ride: 1997 328i
Hey! Dudesky! Talk about perfect timing! I just ordered spark plugs & a new valve cover gasket set, & I'm getting ready to do this job next week!!!
GREAT DIY!!!
johnnybayonne,
Old 04-07-2009, 04:26 AM   #17
jarda
Your Ride: e36 318iS coupe
I can't see pictures - files.unitedbimmer.com doesn't work - any chance of fixing it?
Old 05-15-2009, 08:49 AM   #18
barnutz
Your Ride: 98 328
Pictures?
Pictures are gone?
Old 08-26-2010, 03:55 AM   #19
clarkperez2334
Title: Read Only Club
Your Ride: 1995 Nissan
Impressive one! Thank You!
Spark plug removal, replacing, and maintaining is not as easy as what you think! It takes a lot of effort and time. I already searched and read a lot of forums discussing about replacing spark plug but I found this post the most comprehensive with clear visuals and demonstration! Thanks for the effort... you did a great job!
Old 09-08-2010, 08:43 AM   #20
DSP543GP
Your Ride: 1993 320i
Hi Guys!!!
CAn someone explain to me how to set the click torque wrench, I get confused with the digits setting. On the handle there's plenty of digits. I want to set it to correct specs for the Valve cover gasket and for the spark plugs. Sorry I'm new in DIY. Please help
BMW e36 320i
E46 Light Alloy Wheels
Everything standard and original
Old 10-14-2010, 09:12 PM   #21
krislou80
Your Ride: 2009 BMW 323i
Great DIY!!! I have problem in my spark plug it fires off. so i order some igniter to fire on. any suggestions?
Old 10-18-2010, 10:22 PM   #22
amath80
Your Ride: 2006 BMW
When it comes to your car's ignition system, timing is crucial. With correct timing, the spark plugs fire off simultaneously and electrical sparks are supplied to the engine cylinders at the right moment.the spark plugs can't do everything on their own. They still need an igniter to bring your car's engine to life. Without this simple device, the spark plugs won't function properly.
Car is down Rooz E36 132 01-28-2010 03:15 AM
Compression test Dudesky E36 4 01-21-2006 07:24 PM
