Go Back   United Bimmer Community - BMW Forum > UnitedBimmer- Tech Talk > BMW OEM Parts Department DIY's & FAQ's
BMW OEM Parts Department DIY's & FAQ's Sponsored by: Advance Auto Parts
Discussion of everything OEM with Advance Auto Parts
Old 11-19-2007, 05:42 AM   #16
Rate My Car: 102 / 329
^^^Holy crap, where the eff have you been? Yea, on top of the concrete cinder blocks, it's 2 layers of 3/4" plywood with chocks on the ends made from 2x4's, all glued and screwed together.
Old 11-19-2007, 10:06 AM   #17
defkon99
defkon99's Avatar
Rate My Car: 51 / 329
Your Ride: 1993 E36
lol good to see ya too!
great ill make a note of that. hey one thing think its high enough to pull the trans from under it?
Old 11-19-2007, 03:31 PM   #18
^^^Yes, it was. It fully clears without tilting or turning it to the side, even if your suspension was lowered.
Old 03-07-2008, 08:22 PM   #19
peterkdenny
peterkdenny's Avatar
Your Ride: '96 328is
i just finished doing my clutch! pain in the but, even though i didnt drop the exhaust of the driveshaft. you dont really need to. but, the clutch doesn't disengage when i push the clutch in. not cool. i guess im going to try bleeding the clutch as soon as i can get a pressure bleeder, does anyone have any suggestions?
Old 03-07-2008, 08:52 PM   #20
JetBlack328i
JetBlack328i's Avatar
Rate My Car: 74 / 329
Your Ride: 96 328i
first off my hats off to dudesky very nice DIY write up!!!
peterkdenny are you missing a spring or something? not sure but possibley air in the lines. have someone help you and do it without a pressure bleeder
Old 03-07-2008, 10:46 PM   #21
iamcreepingdeath
iamcreepingdeath's Avatar
I don't think he is missing a spring. I did the clutch change with him. I put the slave cylinder back in myself, i don't know if i had to do something special, i just pushed the slave cylinder back into place, compressing the shaft against the clutch arm, i don't know if i am supposed to like open the clutch fluid reservoir or something like that.
The problem is, Peter's clutch doesn't fully disengage, even with the clutch pedal to the floor. Does anyone know what can cause this? I don't think we missed anything, we were extra careful.
Old 10-02-2009, 09:58 AM   #22
djbmw
Your Ride: 94 318is, 98 328is
Clutch disc in backwards?
Sorry to revive an old thread but for anyone who has encountered the same issue (clutch not disengaging),.. you might have installed the disc backwards. If you did,.. HOPEFULLY it isnt snagged on something. Take the tranny back off,.. remove the clutch disc and ensure that its on the correct way. If you're not able to remove the transmission (feels like its snagged on something),.. you might have fused together the clutch disc with the transmission dust cover that goes over the input shaft - Good luck in getting that off! you might as well smash the bell housing with a hammer to get it off and buy a new transmission.
Old 12-05-2010, 06:16 AM   #23
yudi
Your Ride: E30 (M10)
What can be happen if we are not put marking on drive shaft and transmission side and reinstall guibo coupling not in the same place?
because I just replace guibo coupling with new one and forget to
put or make marking. thanks
Old 12-05-2010, 10:52 AM   #24
djbmw
Marking the guibo, driveshaft and tranny output flange ensures that everything remains balanced. If you want your car to run quiet and smooth,.. make sure its all aligned as it once was. HOWEVER,.. I have switched things around many times on two of my e36's and, although there was some vibration while driving 'unaligned', it was mild in comparison to the vibrations from my exhaust.
There is also the risk of speeding up the deterioration of your drive shaft bearing... or the differential output seal with the new vibrations....
but those are very easy and innexpensive to replace if/when they do fail anyway
The Ultimate E36 Common Faults FAQ Dudesky BMW OEM Parts Department DIY's & FAQ's 31 11-02-2011 07:28 PM
DIY: Installing Silver Gauge Cluster Rings on E36 komodo BMW OEM Parts Department DIY's & FAQ's 19 10-18-2010 11:18 PM
E36 Cabin Microfilter Replacement DIY Dudesky BMW OEM Parts Department DIY's & FAQ's 23 10-05-2009 05:48 PM
E36 M3 Mirror Install DIY (~30-45 minutes) komodo BMW OEM Parts Department DIY's & FAQ's 11 05-08-2007 12:11 AM
DIY (please sticky):Blown Rear Shock Mounts!? E36 Tower Complete Replacment! delmarco BMW OEM Parts Department DIY's & FAQ's 9 08-27-2005 03:16 PM
