Go Back   United Bimmer Community - BMW Forum > UnitedBimmer- Tech Talk > BMW OEM Parts Department DIY's & FAQ's
BMW OEM Parts Department DIY's & FAQ's Sponsored by: Advance Auto Parts
Discussion of everything OEM with Advance Auto Parts
Old 09-13-2007, 11:05 PM   #16
Rate My Car: 173 / 329
i see, but where is this bolt that he speaks of? maybe i could just tighten that, because i dont believe it was sagging before
Old 09-14-2007, 06:16 AM   #17
Rate My Car: 102 / 329
That bolt is news to me. That's why I'm thinking it was an add-on after the factory?? The Bentley doesn't even mention it
Old 09-14-2007, 10:21 AM   #18
3050rpm
3050rpm's Avatar
No, it's not an add-on guys, when I did my first microfilter change it drove me batty too, until I located it. No mention of it in the various manuals, just the usual screws. Later today if I get a chance I'll see if I can get a picture of it and post it here.
Old 09-14-2007, 02:24 PM   #19
well, you keep speaking of it, where is it?(that was my question).. meh, i guess ill find out when i see the pic
Old 09-16-2007, 02:06 PM   #20
3050rpm
3050rpm's Avatar
The angle's a little awkward, but here's the bolt, visible once the glovebox light is removed...
Old 09-16-2007, 06:58 PM   #21
i see, that is VERY helpful, thanks!
Old 09-16-2007, 09:02 PM   #22
3050rpm
3050rpm's Avatar
No need to add to the aggravation of the job by cracking or scratching the light, just be careful in removing it, it seems to come out easier laterally rather than longitudinally, i.e. put a flat screwdriver blade under the (long) side and gently pry, not the (narrow) front edge.
Old 07-30-2009, 12:18 PM   #23
Cartony
Cartony's Avatar
Rate My Car: 95 / 329
Your Ride: 1994 318iC
Wonderful, where are the pics?
OO(llll)(llll)OO
Old 10-05-2009, 05:48 PM   #24
ScottyBoy
Your Ride: 97 e36
I have a small problem on my 97 e36. The blowers blow fine, hot when on hot, and cold when on cold. Until i stop moving.... When i'm stationary, the blowers will not blow hot air, they go cold. Now i'm sure that's not meant to happen, does any one have any ideas?
Cheers.
The Ultimate E36 Common Faults FAQ Dudesky BMW OEM Parts Department DIY's & FAQ's 31 11-02-2011 07:28 PM
DIY: Installing Silver Gauge Cluster Rings on E36 komodo BMW OEM Parts Department DIY's & FAQ's 19 10-18-2010 11:18 PM
E36 M3 Mirror Install DIY (~30-45 minutes) komodo BMW OEM Parts Department DIY's & FAQ's 11 05-08-2007 12:11 AM
DIY (please sticky):Blown Rear Shock Mounts!? E36 Tower Complete Replacment! delmarco BMW OEM Parts Department DIY's & FAQ's 9 08-27-2005 03:16 PM
E36 Interior Luxury Cabin Mods almost done...pictures!!! delmarco E36 13 08-21-2005 06:05 PM
