Go Back   United Bimmer Community - BMW Forum > UnitedBimmer- Tech Talk > BMW OEM Parts Department DIY's & FAQ's
BMW OEM Parts Department DIY's & FAQ's Sponsored by: Advance Auto Parts
Discussion of everything OEM with Advance Auto Parts
Old 02-13-2007, 09:56 PM   #1
Rate My Car: 102 / 329
Thoughts on changing O2 sensor
Just changed out my oxygen sensor and I thought I'd make a searchable thread here in the DIY section. What a pain in the ass, my body hurts like hell from wrenching around in awkward positions under the damn car.
Anyway, some tips . . you'll wanna hit those threads with WD40 and let it sit for an hour or two. Even with that, you'll probably still need a breaker bar to get it to release. If you're searching around and can't figure out what size socket you need, it's a 7/8". But it's a special one you need; one that allows the wire to pass through the socket. BavAuto has them for $19, but forget that crap. Run over to your local Pep Boys, they have the same thing for 9 bucks. Here's a picture of it, with the o2 sensor sitting in the middle of it:
Old 02-13-2007, 11:43 PM   #2
celsdogg
celsdogg's Avatar
Title: never gonna happen
Rate My Car: 129 / 329
this was one of the things i wanted to change on my last bimmer.
what made you change it?
Old 02-14-2007, 07:21 AM   #3
Ummm . . . the CEL One day last week it just lit up. I pulled the code (1221). Then on Saturday, the car kept losing power and I was dropping a smokescreen all over the road like Spyhunter. Took me an hour and a half of stopping and going again after the exhaust cooled off, just to get home from across town. FYI: try not to drive it if it's in this condition; it can damage the catalytic converters.
Old 02-14-2007, 09:13 AM   #4
3050rpm
3050rpm's Avatar
I think it took something like 6 months for my tendons, ligaments, and muscle fibers to reconstitute themselves after I went through that gymnastic routine a few years ago. I think AutoZone lends the special wrenches out for free, after you put down a refundable deposit; nice to see though that you found one for cheap money. You're right, a good soaking with WD-40 is in order, and a breaker bar is a big help. It probably helps too if you can put the car up on a lift, as opposed to jackstands, the way I did it, but that luxury isn't always available.
possible O2 sensor issue. what do you think of these fault codes? bimmerZ5 BMW OEM Parts Department DIY's & FAQ's 5 02-02-2007 01:19 AM
O2 sensor question PhotoGuy30523 E21, E30 2 08-24-2006 04:27 AM
AA o2 sensor sims... ivopivo Vendor/Dealer Comments & Supporting Vendor Announcements 4 03-25-2006 06:26 PM
Potential O2 Sensor Problems Rooz E36 15 06-08-2005 10:54 PM
O2 Sensor replacement Fadec40 E36 15 05-27-2005 09:09 PM
