Go Back   United Bimmer Community - BMW Forum > UnitedBimmer-General BMW Topics > BMW General Discussion
BMW General Discussion Sponsored by: AutohausAZ.com
Talk about BMWs in general. Post official news, Bangle flames, or anything else related to BMW.
Old 11-22-2005, 08:01 AM   #1
ivopivo
ivopivo's Avatar
Rate My Car: 145 / 337
Your Ride: 1993 BMW 325i and 2009 Yamaha R6s
redline...
guys, i wanted to do some 0-60 runs and was wondering how many times is it ok to redline the engine like that. i know there's no certain number but i just want to get an approximation. i know you shouldn't drive the car like that all day but would it be fine to do like 3-4 consecutive 0-60 runs. i basically wanted to see the diff. before and after cosmos intake and fan delete. thanks
-Ivan
LUSTR Auto Detail
"Always start with the least aggressive method!"
Old 11-22-2005, 01:57 PM   #2
DEATH2000
DEATH2000's Avatar
Rate My Car: 116 / 337
Its never really ok to redline ur car. Any time u take it to redline or beyond it does damage to your engine, and after a while that damage can be critical and catastophic to the life of the engine. If u absolutley must do it, only do it once or twice. Ive accedntaily redlined my car before and i really dont recoment it.
Old 11-22-2005, 02:43 PM   #3
TerryY
TerryY's Avatar
Rate My Car: 5 / 337
And I live there when I can and have for almost 50 years of driving.
My 840 has a "Redline" on the tach of 6500 but with the engine and transmission chips it does its shifts at 7000 in Sport.
The trick is to not Float the valves-IE not exceed the rpm where the valve springs can close the valves before the piston catches up and bends them. I would bet that that point is a lot higher than the redline on your tach.
Had a pushrod small block Chevy motor once that had an 11,000 rpm shift point (ran out of airflow thru two Big 4 barrel carburetors at 12,000). That is about 10 times the valve train inertia of an overhead cam engine.
Drive it like you Own it
Terry
Aloha Oregon
'95 840
'98 SVT Cobra
Old 11-22-2005, 02:55 PM   #4
donald1476
Title: President
Rate My Car: 110 / 337
It's fine to redline your car. Obviously it's going to cause more stress which if done frequently can lead to problems. Just think, there is a redline at that point for the reason being that any higher you lose power. Why do you think software and chips raise your redline?
So to answer your question, no it is not bad to redline.
Old 11-22-2005, 02:58 PM   #5
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
Yea I redline mine all the time, after the chip it got raised to 7000rpm up from the 6500 at stock, i dont keep it up there but I will get it there from time to time.
Old 11-22-2005, 03:06 PM   #6
donald1476
Title: President
Make sure you post up the times. I'm interested in the difference, although I'm not ever doing the fan delete.
Old 11-22-2005, 03:18 PM   #7
ivopivo
ivopivo's Avatar
Yea I agree with that.
Death, by redline i meant to shift when it gets to redline, not run the engine at redline. what happened to you anyway ?
-Ivan
LUSTR Auto Detail
Old 11-22-2005, 03:19 PM   #8
ivopivo
ivopivo's Avatar
off topic... how are the pulleys working for you ? was it an easy install ? any power increase ? acceleration ? please tell me everything you can, if you want pm me, cuz i'm thinking of getting those pulleys soon and would like to know if it's worth it and how everything feels. thanks
-Ivan
LUSTR Auto Detail
Old 11-22-2005, 04:41 PM   #9
DEATH2000
DEATH2000's Avatar
They are so worth the money.Takes about just over an hour to install. You really notice a power increase. They give u so much torque over stock that u can really feel a diff. Great mod in my opinon, with some software would be absolutley sick.
Old 11-22-2005, 04:44 PM   #10
DEATH2000
DEATH2000's Avatar
I forgot i was in second gear, and i floored and i was going past 100kmh and it made this really wierd sound and this horrible lurch and i look down and im like "WTF?", i look down at the shifter and im like "oh.....damm". It scared the shit outa me for a second, but im sure it didnt do any real damage. The auto tranny automaticly cuts fuel if it senses the car going past redline to prevent it from damage.
Old 11-22-2005, 05:49 PM   #11
Storamin
Storamin's Avatar
Title: Road Kill
lol... auto.
there is nothing wrong with redlining your car. there is nothing wrong with bouncing off the rev limiter. the car will cut the fuel when it reaches redline reguardless of transmission during acceleration. the problem comes when you're in a high gear, and downshift into a low gear and the revs go up and beyond the rev limiter. this is when things go wrong in the engine. this is assuming you have the stock limiter.
Old 11-22-2005, 06:37 PM   #12
donald1476
Title: President
Old 11-22-2005, 08:15 PM   #13
Rate My Car: 183 / 337
lol donald
ok, just make sure before your redline your engine, that your engine is warm, because sometimes if its still cold the oil didnt have a chance to get all around the engine. basically, the only danger of redlining(under the valve limit, as Terry said) is that IF a bearing or a seal or something goes, it will screw up your engine, and you are only risking that b/c the engine is spinning much faster..
and donald, change ur sig that is soo annoying!
Old 11-22-2005, 09:18 PM   #14
DEATH2000
DEATH2000's Avatar
Donald, lemme rephrase the second quote if i may. I meant to say any tim u take it past redline when not in gear or down shifting it does damage. Better?
Old 11-22-2005, 09:57 PM   #15
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 119 / 337
Your Ride: ^^
my syncro on my manual tranny wont let me downshift at a redline speed..ie downshifting to 2nd gear @65. maybe my trannys just old..idk
as for redlining..i redline 3-4 times a day if not more..car runs fine. spiffs old E30 had 200000 miles on it...and he still redlined it daily.
Considering Buying An E30?Upgrades?Differences? spiff E21, E30 30 04-14-2012 10:12 AM
