Go Back   United Bimmer Community - BMW Forum > UnitedBimmer-General BMW Topics > BMW General Discussion
BMW General Discussion Sponsored by: AutohausAZ.com
Talk about BMWs in general. Post official news, Bangle flames, or anything else related to BMW.
Old 03-01-2008, 12:56 PM   #1
dterrie
Your Ride: 2007 328i Coupe
2000 323ci - no maintenance history
This is my first post. I own a 2007 328i Coupe (love it). Way back, owned 1980 528i. The car is for son.
I've test-driven a 2000 323ci at a small used-car dealership. It has 97K miles. Steptronic, Sport and Premium, etc. Very clean inside and out. Tires in good shape. Engine smooth and responsive - compared better than expected. Tested alignment highway taking hands off wheel and car tracked straight. Handling on a fast run around highway exit ramp seemed good. However, going over a patch of rough pavement, the bumps felt harsher than I expected. I've checked enough forum posts to be aware of subframe issues, especially with coupes. The salesman says he does not have ownership / maintenance history on the car.
He wants $13K. The KBB is $15,140.
Should I pursue purchasing this car, if it checks out OK in an inspection?
Is there a way to find out the car's history through the VIN?
If I can't discover it's history, and the subframe, etc. checks out ok, are there still enough unknowns to make purchasing an extended warranty a good idea (not normally a fan of these)?
In short, am I taking a big maintenance risk here, or should I be ok, if car checks out?
Old 03-02-2008, 12:17 AM   #2
xxxbimmer
Rate My Car: 46 / 337
you can look up the car on carfax........ALOT can go wrong on a car at 100k especially if the cars maint was less than perfect... and the sport pkg makes the ride more harsh fyi..... i would get the war for piece of mind
Old 03-02-2008, 09:55 AM   #3
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
If there is any chance it was serviced at a dealer you might be able to get them to pull that info up on the vin? A carfax is probably not a bad idea either.
Old 03-02-2008, 10:20 AM   #4
celsdogg
celsdogg's Avatar
Title: never gonna happen
Rate My Car: 128 / 337
i probably wouldn't purchase it. with that many miles you dont know what happened to it. even more than that, the gearbox and diff oils were probably never changed, and if thats the case, the gearbox will most likely fail somewhere between 100 and 150k miles.
Old 03-02-2008, 05:34 PM   #5
denyo77
denyo77's Avatar
Title: REINHEITSGEBOT
Rate My Car: 198 / 337
Your Ride: 1988 325i Touring
the M pack is an upside to the car, tho...
Deus ex machina
E30 325i Touring
1999 528i Maintenance costs jsnoland E12, E28, E34, E39, E60 3 11-28-2007 12:03 PM
Maintenance c1apton United Off Topic  **FOR MEMBERS ONLY** 12 05-15-2006 03:04 PM
CARFAX please!!! Turbodefrost United Off Topic  **FOR MEMBERS ONLY** 6 06-27-2005 12:31 AM
need car fax brien4787 United Off Topic  **FOR MEMBERS ONLY** 2 06-09-2005 11:41 PM
History of the M3 komodo United Off Topic  **FOR MEMBERS ONLY** 9 06-05-2005 06:16 PM
