I didnt want to steer you wrong so decided to see what it would take to actually remove mine. You will need metric allen wrenches and torque bits, at least i did. you can remove just the pulley too instead of the whole tensioner assy, might be cheaper if you can get just the pulley. You want to make sure which pulley is making the sound because there are some idler pulleys which could go bad also.
