Old 03-04-2006, 07:40 AM   #5
Rate My Car: 134 / 340
Bav Auto has the hi perfs for 449.00 and they're worth the investment. But before you jump into them make sure all else is ok. Clean out your MAF, change fuel & air filters and run a good cleaner through the fuel system. (Also check for vacuum leaks - cracked or loose hoses) You'll be really upset if you invest into coils only to have same symptoms.
