Old 02-21-2006, 10:46 PM   #11
Antiburn
Antiburn's Avatar
Rate My Car: 176 / 329
The seals never leak, banjo bolts bont leak unless there loosesed. Your PS hoses, most likely the one from the resivior to the pump or from the pump to the rack are leaking. They arnt the hardest to fix, just make sure you get new clamps and washer seals. For an E30 the hoses should run you no more then 200$.
