Old 02-19-2006, 07:34 AM   #9
Rate My Car: 106 / 340
Unless AMD's design has changed recently, the heatsinks they provide are all aluminum. Better aftermarket sinks employ either all copper construction or a copper slug where it contacts the cpu core, which equates to better heat transfer and dissipation. And the fans they use are typically innefficient and break down easily. This is especially critical if you're planning to overclock the cpu. Even so, I still say AMD over Intel FTW!
