Old 02-09-2006, 02:28 PM   #7
doughboyea
doughboyea's Avatar
Your Ride: 2007 Acura TSX
Originally Posted by Antiburn
Just keep the key on KL15 for 15 seconds and the light will go out.
Did my rear brakes last October-ish. Brake light went out after the install and the single pad sensor was installed on the passenger side caliper. Turned on the power, waited like 15-30secs. Just power, no running engine. It came on at first, but as the computer went through it's check list, the light went out. Didn't need to reset any codes. If your still having a problem, you may want to consider checking to make sure that the sensor is attached correctly. If it's loose, wouldn't it still be considered broken...?
But I just realised that this thread is a few weeks old... so... did you fix it?
Dough
Current Ride
2007 Acura TSX w/Navi
Past rides:
1989 Mercedes 190E 2.6
1980 Mercedes 240D
