02-09-2006, 08:14 AM
#15
Your Ride: Nothing .. for now.
Originally Posted by Antiburn
Check your coils, there is a recall for out of date coils. They cause check engine light and misfire. Pull a coil out, if its all black then you need the updated ones. Check all 6 cylinders too. You car should still be under warranty unless youve over-ran the milage so they will give them to you for free.
define: coils.
Member of the First 5 Uniters.
