Sounds like you dont like spending money on your car.. on a 95' brakes are probably getting to the point where they could use a full rebuild, especially in this area of the country where corrosion is a given..
fan = dont need it (understeer kit is like 90$ if you choose that)
themostat = 23
thermostat alum housing = 26.50
thermostat gasket = 1.50
waterpump = 59
waterpump gasket = 5.50
belt = 17.50
pulleys = 32
radiator hoses = 20.50 for upper/lower
185.50 for everything, and im sure these arent even close to the best prices out there (
www.pelicanparts.com). replace the thermostat and waterpump now if you havent.. mine as well with the hoses already off and coolant drained. Oh yeah.. 20 bucks for bmw coolant.
Whats your suspension like? control arms, cab's, tie rods, rtab's, rear cab's, sway links, etc.. 900 bucks will replace every bushing on your car, along with the brakes, and the cooling system. If you can tie your shoes, you can do the work yourself.
