Old 12-24-2005, 05:07 AM   #7
Rate My Car: 106 / 340
If you used a new crush ring that comes with the filter kit, there should be no problem, unless you have some sort of gouge at the pan opening. Are you sure the leak is coming from the plug? E30's are known to have oil pan gasket leaks, could that be another possibility?
